What would the beginning tuner need to get started?
I know that an ECU chipping kit, ECU, wideband o2 sensor, datalogging cables, and a compatible computer with the proper program is necessary. Is this all that's needed to get started?
Now, what tools can increase the options? An Emulator such as the Ostrich? Exhaust gas temp sensor? Vac gauge?
I'm interested to know what tools are absolutely necessary, and what tools can be added to the setup later for better results...
There are already instructions for chipping around, so he'll probably just link to them. Regardless, it'll be worthwhile.
), but I can def feel a difference. even if you dont FEEL a difference, you can definitely make a difference in your gas mileage. I ran my stock ecu and got about 23mpg in the city, and now Im runing my chipped ecu, im sure I can get it to the 25's in the city. i have about 200miles already and about 1/6 down from the full mark. my afrs are never dip below the 14's during cruising and normal driving. once I go wot, the richest it will get is about 13.8, and thats at the very top end. besides that, my afrs are between 14.3 and 16.5. big range, but hey, thats pretty good for only going off a wb. my idle is too lean tho, it sometimes goes to 17.21 :o
