Hey Ive had a CEL on for awhile since I installed my Plx m-300 unit. I remember reading somewhere that I have to install some resistors I believe where the old O2 sensor plugs in? If someone could point me in the right direction that would be golden, thanks.
Plx m300 install and CEL fix
sorry to jump the gun.
I believe I need this if someone could make sure its the right idea:
20 ohm 10 watt Resistor below
http://www.leedselect.com/images-res/20ohm10w.JPG
which gets connected as close to the ECU as possible.
its not supposed to be a resistor, its supposed to be capacitors. what they do is just "filter" any noise that might interfere with the signal and make it less accurate. thats why its best to put them near the ecu. they are not really necessary, but if you want, you can still install them.
heres the installation guide
http://plxdevices.com/InstallationIn...UsersGuide.pdf
anyways, which cell are you getting? I'm gona go ahead and say its the one for the o2 heater circuit. the reason its lit is becuse the circuit is not complete. you need to get a fuse to complete the circuit.
that, or disable the o2 and the o2 heater in uber/crome.
there was a thread that hemlocks made about the installation of the plx m300 a while back.
