*A nice Tuning Write up*
    THIS IS FOR CROME AND UBERDATA WILL BE SIMILAR... VERY SIMILAR INDEED...
    I will list any info i have that can help and even list only Stable OBD-1 editors, being Uberdata OST. version and Crome Latest version...
    (OST. = Ostrich live emulator/tuner)
    SOFTWARE:
    CROME Stable Download: CROME NEWEST STABLE VERSION (RIGHT CLICK SAVE AS)
    READ THIS AND DOWNLOAD THIS TO ADD 2-step/FTS/Bcut FUNCTION TO CROME: READ DOWNLOAD
    Uberdata Stable OST. Download: Uberdata NEWEST STABLE VERSION (RIGHT CLICK SAVE AS)
    Uberdata comes with 2-step integrated and Bcut and FTL
    Here is the write up for How to use crome: READ
    IF you r using Uber Contact D112crzy for the Binary File (Binary File is the File that Contains the Fuel and Revlimiters and Ignition curves)
    For Crome Start With a LS Bin and dont touch the timing it is similar to the F22a motor`s. Tune the Fuel, u will need to tune since noone i know of has the stock Binary for a F20/22 motor SOHC/DOHC.
    Uberdata is CLOSED SOURCE and CROME is OPEN SOURCE Which Means pick your editor, i like crome, cause what happens is If u make a ROM or Binary in Uber you can open it in CROME if you switch but idle, rev limiters, everything else is not able to be used you can only modify FUEL and IGNITION curves... and If you make a Binary or ROM in crome it cannot be opened in Uber at all.
    If you Have a car with IAB`s u need to use a GSR ECU so you can control the IAB`s. Or you need to use a P28 (Dont know if it will work on other ECU`s modified to a P28 Spec.) ADDING IAB`s to P28
    IF YOU DECIDE TO USE UBERDATA WITH A "LIVE OSTRICH EMULATOR" DOWNLOAD ACCORDING TO THIS PAGE TO UPDATE THE DRIVE IN THE OSTRICH EMULATOR FOR UBER, WILL WORK WITH CROME BUT HAS A SLOWER UPDATE RATE- READ & DOWNLOAD ACCORDINGLY! (ONLY FOR EMULATOR NOT BURNER
    A emulator Allows you to tune the car while its running, but you still need a burner to "burn the chip after you tune it, for awhile i just used a burner but u have to pop the chip and reburn it everytime u need to change settings, with the emulator i shave the time into 1/3 while tuning a customers car... Just because of the simple fact I have to pop the chip everytime i bought a god damn emulator!!!
    If you sign up at PGMFI.org it will help you understand more and also to let you know, you can ask me anything, i have been doing this for 3 1/2 years and have done tons of cars, ask questions and i will help you. on PGMFI.org you can also learn about CROME`s other plugins lie A/C cutoff and FTS (Full Throttle Shifting, Eliminates lag on Boosted cars) and Open Loop Threshhold Switchover by TPS... Again as you can tell I like CROME more
    HARDWARE:
    LAPTOP: Windows 98 or Better
    Chip Burner of my CHOICE: Moates BURN1 ("Burns" the Binarys to Your Chip)
    CHIPS: Use the 27SF512 Chips they are the cheapest from MOUSER.com
    MOATES OSTRICH EMULATOR:
    APU1 FROM MOATES.NET: This Will Do the job of the Emulator & BURN1 in one Package
    A WideBand O2 SENSOR (WBO2): I like the INNOVATIVE LM-1 or LC-1 i dont remember (the one with the Display)
    Datalogging cable: you have to buy datalogging with CROME and the stable newest version of Uberdata Doesnt have datalogging so i watch the wideband while driving, i tune the cars at WOT (wideOpen Throttle) then do partial throttle and idle... Works for me i have good eye watching skills and get all the of the A/F`s where they need to be Within .2-.3 A/F points... Works for me... *Shrugs shoulders*
    I suggest Buying From:
    www.XENOCRON.com
    www.MOATES.net
    www.MOUSER.com
    Good Luck To everyone.
    GET A TUNING QUOTE FROM ME AZ PEOPLE
    "TÜNE.FREE Engine Management!"
    ...::SHAWNEE::...
    so your saying my p06 will not control IAB's?
    miss my turbo cb7
      you can data log very easily and effectively for free!!!! Use freelog and 232 data logger. I highly recommend that you try it. yes a p06 will controll iabs.
      spin city
        Not unless you add in that functionality by adding a few components.
          Nice write ups, too bad I am too lazy to learn to do that.
          Click Me
