ECU Problems!
    ECU Problems!
    I have an '97 Accord SE, I put in an '95 Accord EX VTEC engine. The '97 is of course OBD 2 and the '95 VTEC engine is OBD 1. I purchased an conversion harness that would allow me use the '95 EX VTEC computer with the '97 Accord wiring harness. I currently am running the '97 ECU on the VTEC engine. It's running like S%$T, what can I do to get this car running right? I need help bad!!!!!!!!!!!!!
    if ypu purchased the harness why are you still using thr 97 ecu.
    if you got something smart to say, guess what, i dont care.
      It Won't Plug In
      For some reason the Conversion Harness won't plug into the '97 Accord's harness. Why I don't have a clue, they said that it was an OBD 2 to OBD 1 conversion harness. I have to get the correct ECU running this engine so that I can access anyother existing problems.
        have you gotten your harness yet? you need the conversion harness to be able to plug in the obd1 ecu.
          u sure ur not plugging it in backwards???(not an assult on ur intellegence)...or probably the company(the harness ur purchase from) sent u the wrong harness...but yea u should be using the 95 accord ecu...
          A wise man sees failure as progress...
