Is it worth it?
    Is it worth it?
    Moates Hulog
    USB Datalogging
    With this device, you can perform datalogging on your Honda ECU using USB as your PC interface. Comes with converter box, USB cable, and a cable to go from the box to your 4-pin header on the ECU. Comes with CD for drivers and install instructions.
    source: www.xenocron.com
    Your car is faster, I'm the better driver
    Greetz Erwin
    My last ride
    Shakes and Fidget - The Game
    Does it work on your stock ecu or do you have to pin another socket in it?
    Greetz Erwin
    My last ride
      The one in that pic is socketed. Probably better to email Xenocron to get an answer on whether or not you can use it on a stock ECU
      1993 Prelude S
      F22A1
      custom'ish turbo setup
      180 whp/217 ft-lbs super hot, super humid, super rich, boost falling off at 8psi
      18psi boost spike = BOOM!!!!!
      currently being rebuilt
        Typically you use a datalogging enabled rom and depending on your software you may need to switch your ECU to full duplex instead of the default half duplex.
        What is your goal?
          What is your goal?
          More torque.....
          Greetz Erwin
          My last ride
            Well for that you'll need to tune it and you can not tune your stock ECU. You will need to have a chipped ECU such as a P06, P28, P74, P74, etc. with a base map (tune). Then within your tunning software using things such as datalogging, realtime monitoring, tuning, and etc. you can make changes to the map and adjust your tune accordingly to achieve your desired results.
