f20a DSM turbo???
    f20a DSM turbo???
    Got an f20a swapped into a friends 90LX, but curious as to mods. Curious as too cams, rods, gears and pulleys avaliable. I personally figure anything h22-23-f22b will fit. Dont know if i'm right though...He's also asking me about my dsm turbo setup on my f22b...can you pull that off the the f20a? Its pretty much the same engine afterall.
    Thanks guys.
    Confucius say...when god gives you gators...make Gatorade
    its been done....
    Formerly 91AccordExR33
    11.68 @ 127mph
    417whp/375wtq
    Sold: 8/2016
      ^werd
      did gdout have a f22b as well?
      ~Nick~
        hey 91accordexr33, how was that under boost. i just cranked up mine yesterday, its on an 11lbs flywheel, still n/a, and shes a peppy lil thing. just wondering how it did with boost and you would recomend for the amount of lbs to run. i figured 7lbs daily would be good, and carlos said i can run 11lbs. that the reason you had problems was wastegate causing a boost spike or something. let me know. i appreciate it.
        Originally posted by d112crzy
        So you're throwing a bitch fit because some other girl at school has the same nail polish and skirt as you do?
          woah...If you can can you post a few more detailed pics of your f20 set up? I'd like to see what you did with the pump and such. Would be greatly appreciated.
            I'm having an argument with my bud over my build. I've relocated the battery to the trunk, he thinks I should put a TMIC where the battery was and put a custom vent on my hood...I think I should dremel out the stock 91 bumper for an FMIC...its 2.5 In/out since I'm using 2.5 pipe...any clues or ideas guys? Really want to get this build underway, but I need to settle this lol. PLus hes arguing that the TDO5H with 450CC injectors will empty my tank within less than 50K of travel...ARGH
              If you have the pedal on the floor for those 50 kilometers...
                Well, I'd assume so, but i'm not going to be doing that obviously @_@...I just want to know how bad my fuel comsumption is going to be hurt :/ its my daily driver.
                  man take a look at homemadeturbo tuning section, and pgmfi, if you research and know what your doing, your highway cruising mpg wont be affected much...alot of guys are getting better than stock!
