FMIC with ac and stock bumper?
    I haven't seen anyone on the board with a turbo setup with a fmic and the ac still in and functional, with the stock bumper on as well.
    Is there simply not enough space, or have I not looked good enough?
    I dont think there is enough space honestly, but Im not certain it hasnt been done. I know that with my wastegate dump to atmosphere, there is for sure not enough room down there for it, but I had it removed with the 14b. It is very tight down there, so it might be possible, but it will make it harder to manuever your hands down in there.
      gdoutaccord still has a/c on his setup.
        accordsir still has his a/c also...its a tight fit.
        instagram @mikeymeyagi
          what material are the lines, i have a guy that can weld aluminum and another guy that does stainless. also what sizes are the pipes? there are two pipes right? a high pressure and low pressure pipe. there is enough room i think, but i want my pipe to run down near the crossmember for a cleaner look.
          Originally posted by d112crzy
          So you're throwing a bitch fit because some other girl at school has the same nail polish and skirt as you do?
            I still have yet to see a 92-93 with oem fogs and a FMIC.... Turbo CB7s with A/C has been done
            I need a custom turbo manifold built....
            707 NorCal NinjaZ
            Honda Twincam Motorwerkz?
            "I am the Yakuza CB7!"
            '92 Accord Sedan SiR
              Iamanonymous used to have full AC Setup on his car with a stock 90-91 front bumper. I forgot what size turbo but that thing was cramped to hell. The car is gone now tho. It is possible to have AC its just how you route the turbo and how much room you have to play with. Some people say there is more room in the 92-93 bumper so I dunno.
                i am going to try and get oem fogs to fit. they will be depo brand though. i think if you can get teh fmic to sit far enough back it will work, but the only way that will work is if you take those two p/s coils out, which mine are gone so we will see here within the next couple of months. oh and i want to run at least 2.5" thick, if not 3" thick with fogs. i will do my best.
                doest accordsir have fogs too? i think his fmic is mounted "upside down" to fit the fogs. or am i wrong on that one.
                  My fmic is upside down technically, but I do not have fogs.
                  Id like them, but cant justify the money for them.
                  Not sure on accordsir however.
                    My ultimate goal is fitting a fmic with the stock 9293 bumper, and the a/c still in, and fog lights...i hope it can be done...ill figure something out.
                    Sounds like its not impossible, just really damn hard LOL
                      Accord SIR is doing the 92-93 oem bumper. He has routed teh FMIC to where he can utilize the fogs. Its not too bad if you can modify the end tanks.
                        Thanks Nail, i'll have to check out his setup
                          youll see mine soon with AC
                            Sweet, I can't wait to see it, I need ideas for my build. With the summers getting as hot as they can in St. Louis, I can't go without a/c, but I want to go turbo.
                              They exist. I'll be doing it over the next couple of weeks. If i want a/c that is.
