ok well i took my car to the exhaust shop(towed cuz no downpipe yet) but when i got it there they said there is no way to fit an exhaust......The o2 housing outlet comes down right above the oil return line.....Did i do something wrong? PLEASE PLEASE PLEASE CHIME IN ASAP!!!
Downpipe issue.....
there is always a way to fit the exhaust. O2 outlets can be moved, exhaust shops can easily do it. What did you do wrong? Any pictures?Originally posted by chrischhornok well i took my car to the exhaust shop(towed cuz no downpipe yet) but when i got it there they said there is no way to fit an exhaust......The o2 housing outlet comes down right above the oil return line.....Did i do something wrong? PLEASE PLEASE PLEASE CHIME IN ASAP!!!DEVOTE
FS: Lokuputha's Stuff
X2 that ... get you a bung kit, plug the old bung and have the shop weld in your new bung just make sure they put it before the cat but after the manifold for best results ... at least thats what my LC-1 book saysOriginally posted by lokuputhathere is always a way to fit the exhaust. O2 outlets can be moved, exhaust shops can easily do it. What did you do wrong? Any pictures?
Can you not move the oil feed return line out of the way a little bit?
Edit: If all else fails, you could get the dp fabbed, and either close the hole on the oil pan and replace your return fitting, or get a new oil pan and just redo it. Regardless, it seems like it should be able to be moved.Last edited by chessboxer; 04-22-2008, 05:06 PM.2010 Taurus SHO - Livernois Goodies
oh you have a turbo system...
put a 90degree fitting on there and move it along the oil pan away from the down pipe.DEVOTE
Or you can just get a longer line and route it elsewhere.
