I just started noticing that my car runs lean everytime i hit the throttle and get into boost. but when im just crusing the wideband is showing around 13-17. when i hit the throttle it gets down to 10. im worried about the block. any info?
Runs lean only on full boost
Originally posted by quickangel93 View PostI just started noticing that my car runs lean everytime i hit the throttle and get into boost. but when im just crusing the wideband is showing around 13-17. when i hit the throttle it gets down to 10. im worried about the block. any info?
A lower number means a you are going rich, but under boost, you dont really want to see an afr over 12.5 most of the time, and generally speaking. There are times when people run beyond this, but under boost, it becomes somewhat risky.
Remember, it is Air to Fuel Ration, so a lower number means you have less air than fuel and a higher number means you have more air than fuel.
Also, each type of fuel, gasoline, methanol, etc, has a different stoichiometric reading, so when you switch fuel types, these numbers change.
But that is a whole 'nother lesson kiddos.
F it, here is a free lesson from your good friends at wikipedia.
Fuel
Gasoline 14.7 : 1
Natural Gas 17.2 : 1
Propane (LP) 15.5 : 1
Ethanol 9 : 1
Methanol 6.4 : 1
Hydrogen 34 : 1
Diesel 14.6 : 12010 Taurus SHO - Livernois Goodies
