forged rod for F22?
    forged rod for F22?
    since i have a cracked piston i want to rebuilt it with forged pistons and rod. i found a wiseco forged piston kit but i dont find forged rods..
    so which compagnies makes forged rod for our F22?
    which rods are you running guys?
    My Ride
    Jas Airbrush, Custom Paint.
    www.importperformanceparts.net
    www.raceeng.com
    Those are a start on a couple known places to have F22 internals.
      i didnt find any cheaper end rod solutions at IPP.
      the ones i bought off ebay have the same part number that eagle uses. those are forged H beams and still lighter than stock. i needed to hone the big end out since they got the wrong dimensions on it for some reason.
        i'm not sure to understand..
        My Ride
          maybe you shouldnt be touching the internals then.
            lmao
            smoke tires, not drugs.
              Originally posted by slammed4thgen View Post
              lmao
              unfortunately there's more to a motor than just to bolt everything together.
              even deburring is an art.
                i'm not sure to understand because i'm not 100% functional with my english..
                what is IPP?
                and what is ''hone''?
                My Ride
                  IPP = import performace parts
                  hone = term in machining, can be used to get the proper sizing or clearance usually after boring or reaming.
                    The word "hone" is used to describe the process it takes to very lightly and very evenly score the cylinder wall. You need to do this because you want a good rough surface for the piston rings to mate with and make a good seal.
                    If this process is overlooked you could face issues with low compression and blow by. Blow by is when the combustion gases pass the rings and enter your oil system. Is is also very very bad.
                    Been a long time. Still alive...
                      it's a universal term in machining and in my context it was for honing the big end out on a rod to achieve the desired clearance.
                        how much power are you looking to make? there is a good chance you dont even need rods to be honest, the stock ones are pretty stout (still yet to see one fail under boost).
                        its the D series rods you have to worry about, they dont call 'em toothpicks for nothing.
                          thank you for your responses guys
                          i dont want a lot of power.. maybe 300hp.. so like you said the stock rods will do the job.
                          My Ride
                            id be safe and get aftermarket rods, plus you have to make sure the wiseco pistons are press style pins to accomadate the stock rods.
                              you will make more horsepower at 12 psi with a 16g, than a 14b. Not to mention less hot air coming from a 16g, heat kills.
