So this is a bit more of a rant than anything, but, here goes. I'm building an H23 for boost. I have about 98% of my parts to complete the project. I'm shopping for a headgasket. I was told i need to use a .050" thick gasket by the machine shop that built my motor. Reason being that, the block i started with had spun bearings. I didn't know the main bearing's were spun too. They were able to save the block, they just had to slightly move the centerline of the crank UP in order to use it. This obviously makes the pistons stick up just a wee bit past the deck at TDC.
This is the reason i need to run a thicker than OEM headgasket. I was told it wasn't a good idea to run a cometic headgasket, because supposedly they sucked for boosted hondas. This is why i never looked at them. I found out about SCE Copper Headgaskets and finally gave them a call today and found out that to get a custom gasket from them would be like close to $200.
Anyways, i give Cometic a call and they tell me, they don't even MAKE an H23A1 gasket. I have even tried Golden Eagle and they don't make one either. I'm just kinda pissed off and looking for suggestions on where i can go from here besides SCE. I really don't feel like dropping 200 dooleros on an effing Head Gasket.
SOMEONE !!!!! PLEASE!!!!
