Spitting in boost
    Spitting in boost
    Ok so i am kinda clueless on why it is spitting in boost. It only seems to do it when i am WOT though. So far i have replaced, spark plugs, fuel filter, sea foam, put injections cleaner through the system. Now all this start happening about a month ago or so. I started to notice after i ran the car up to 130mph.(stupid i know i was in a conflict with a v8 mustang and when i saw how fast i was going i stopped) But ya so i am clueless. It is currently running on chrome pro. So any ideas would be greatful.
    ~Nick~
    spitting?
    like missing?
      you replaced the plugs but did you gap them low?
      youve been out the loop for a while man..
      what setup you running these days??
      boost?
      etc?
      get on aim...
      Praise The Lowered...
        Never overlook your plug wires...
        -Big3racing.net-
        My Build Thread. Many pics.
          t stat ground.
          plug wires.
          plug gap.
          or ohm test your igniter.
            whats your tubo setup again?
              i say check the plug gaps and also check and make sure a injector didnt pop lose
              LIONS GARAGE
              GARAGE*FRESH
                I mean breaking up. Popping like it is being held back
                ok current set-up is
                f22a4
                precision sc-60
                450cc injectors
                38mm tial wastegate
                50mm tial bov
                custom log style manifold
                Running 9-10psi
                As for plugs i have them gapped at .032" i am going to lower them down to .028" this weekend and see if this does anything.
                I replaced the plug wires not even a year ago with ngk blues
                As for the ignitor i just replaced it but i know how easily they can give out i have a spare one i will swap and see if it changes at all
                ~Nick~
                  how many pounds broski?
                    9.5-10psi
                    ~Nick~
                      internal or external coil? When i was breaking up I found a faulty coil wire - connections were rusted to shit inside of the insulation
                      Formerly 91AccordExR33
                      11.68 @ 127mph
                      417whp/375wtq
                      Sold: 8/2016
                        I am running an msd coil blaster. Did the conversion. But the coil blaster is new as well. I haven't replaced the coil wire that connects to the dizzy.
                        ~Nick~
                          i just had an issue like this. does th tach jump around any?
                          check out the website
                            try gapping the plugs down to .025".
                            I assume you're in 5th gear at 130mph, under heavy load you may be leaning out, that could cause the spitting. Where are your A/F's and how much timing are you running?
                            I suspect that the plug gap is the culprit.
                            -Kyle
                            SOHC Non-VTEC F-series for life
                            "It is the fools prerogative to utter truths that no one else will speak."
                            -Morpheus (The Sandman)
                              -Kyle
                              It does it in any gear once i reach full boost i am going to gap them today
                              ~Nick~
