Turbo install. Few quick ?'s
    Originally posted by WiKKeDV16 View Post
    Imo if considering a dsm setup..I would opt for a ebay gt manifold..its fitted with a 38mm wastegate port..thus you will have no chances of boost creep..
    Secondly either run a big front mount..or if your hell bound on the top mount which would be a pain to fit..id suggest definetly running methanl injection. To aid with knock due to the higher temps you will experience with. A tmic.
    Start out at low boost..until you get everything setup approprixately and the car running good
    Don't even attempt a boost controller with a dsm setup. Especially with a 14b..its just too small..its a good starting point so I won't knock you for that..but as far as raising the boost..before raising..upgrade..to a evo316g or a 20g..and you'll make more power at the same psi level..
    Well im starting with my DSM set-up for the rest of this year. This winter the car will undergo huge changes.
      Originally posted by rexload View Post
      air-to-water setups start from ~$300 and up
      they are usually more efficient but there are more parts so it would take a little longer to install, i can't think of any other cons
      nothing is needed for DSM injector install, nothing needs to be modified, they are direct fit. you don't need another resistor box, the Accord already has an injector resistor box.
      Even with an H23 IM?
        SMIC where the battery was...
        its a good idea if you can get enough air flow to that spot, which means ricer hood, no thanks..
        but a sprayer would be sweet as long as you have fresh air comin in!
        I would not recomend just spraying either, maybe a little of both!
        Good luck!
        MadLab Racing
        Southern Maryland
          Good luck!
          Is that a supra SMIC?
            Just got another 14b and 2g mani and front mount for 150 so no need for a smic lol.
