uberdata basemaps?
    uberdata basemaps?
    help out here guys, i need a f22a basemap, with 450 injectors, but non-turbo.
    just need a rough idea on one, so i can run my car for a week or 2 with the 450's, any help is greatly appreciated.
    -sean
    MRX has a basemap, I think he has one for a non turbo and turbo. otherwise check out the uberdata forum if you haven't already done so.
    Shift_BOOST
    BOOM!
      mrx only has the turbo basemap, and there's nothing on the uberdata board or pgmfi.org.
      but i got the mrx map to work. without a cel.
        palm bay, fl huh...how close is that to jax?? Would u mind taking a trip seeing as i wouldn't be able to get to u? I'll modify my turbo map just give me a VERY detailed description on whats dead on and what needs work. Describe idle conditions, idle speed, slowly rev up to 5k describe that, hold 2500rpm describe that, and so on.
          mrx, its the same as i described on HMT. i messed with the fuel maps a little bit, and turned off all the boost settings and it works fine. i just worries me a little bit that i can't tell what's goin on since i don't have my datalogging cable yet.
          palm bay is about three hours south of jacksonville, not to bad, but it's still a drive. i'll be boosted in about a week and a half, and i'll update you on how your basemap runs with my setup. until then, i'm driving it as it is, even though the idle is a little low for my liking.
          thanks for the help though.
          -sean
            did u try just adjusting the idle screw?
              no, its still idles, i just didn't want to mess with it until its boosted, maybe i'll do it some time this week
