Wastegate spacer
    Wastegate spacer
    I have a external wastegate. The way my manifold is I need to space it another 1/2 inch to clear the alternator.... Spacing it will not effect functionality correct? How hot does the compress housing get? I am worried about killing the alt since it only has about an inch of clearance..
    I have this style wastegate
    the gate hat will get suprisingly hot. but not hot enough to ruin an alternator from an inch away.
    and if your using a quality gate, you wont see any issues.
    if your using a TiAL "style" gate, you will probably have some problems anyway.
      I'm not worried about the wastegate heating up the alt... It was the turbo itself... I need to space the wastegate out because it would not be possible to run a ?dump tube?
      What wastegate would be more reliable?
        well everyone with a boosted f22 or h22, anything with a front mounted alt. (b and d series mount in the rear) has a turbo 3-6 inches from their alternators, and i havent heard any horror storys.
        and anything that doesnt say JDM sport on it.
        haha
        Tials are the most common. there are others, like Synapse, that most people havent heard of but is still a quality gate. Even a turboSmart would be better than some of the no-name garbage.
          my turbo manifold is 1/4 in from alt no problems and yes you you space the wastegate accordinly
