having problems on my car HELP PLEASEEEEE
    i tried pulling the codes but the engine light doesnt blink like how eric said.
    is that the blue plug dat im suppose to put a paper clip to?
    i got my fuckin chip burner yesterday but didnt come with no cable wires or the instruction or nothing, not even the program for it. eric tried sending me the program but everytime its bout to finish my aim froze up. hey midnite you think u can send that program to my email and that new map you got? my email is gdoutjm@hotmail.com aite thanks
      next time you open up the ecu. see if there are any brown burn marks anywhere. sometimes that can tell you if the ecu i fried or not. i personally dont think its the ecu, it could be the chip itself, but i doubt the whole ecu is junk. Im also confused as to how this would cause the timing belt to come loose. i personally think that has something to do with it. If it was something with the program on the chip, my car would be doing the same thing
        ok heres the pic of my ecu and i dont see any brown burn marks but i see a white mark next to the chip
        heres how i put the new chip, like how it was with the old chip.
        and the back of the ecu and i dont see no brown burn marks either
          the ecu looks good..probably need to reflash or reprogram the chip, thats all.
          5.6L V8 32V DOHC
          JDM HERITAGE - US BUILT
            NOOOOOOOOOOOOOO!!!!!! chips in backwards man!!!
              problem solved
              5.6L V8 32V DOHC
                Originally posted by PRIMOCB7
                problem solved
                mabye not...that can do a lot of damage.
                  yeah man, that chips in backards dawg.
                  i was gona say did u have anything else done to the car, cause i know when i put my clutch and stuff in and finish the car would go pass 3k rpm.....turned out to be my speed sensor was f-ed up (fucked it up during installing my trans/clutch) and my FTL setting kept kicking in. fix that and it was fine...
                  but from the pictures u showed us.....that chips in backwards, turn it around and hopefull its not to late, it can mess shit up installing it wrong.
                  also to credit my man R33/Midnite, they do a good job on what they do so Draztik....chill out man and stop trying to diss someones work for no reason...get your post count up before u try that
                  NEED RAP BEATS.....
                  www.soundclick.com/akcidentaltrakz
                    fuckkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk kkkkkkkkkkkkkkkkkkkkkkkkkk
                      the good news is you probably only fried the chip. What happens when u plug the chip in backwards is the ecu gets confusing information. Every pin tells and delivers info to the ecu. When u put it in backwards its like connecting your negative terminal to your positive. A sure fire way to tell if the chip is in backwards is keep your finger on it when you turn the ignition on. Don't turn the car over but just turn the ignition on. The chip will start to heat up instantly meaning your burning the circuitry inside of it. ALWAYS...ALWAYS HAVE THE ARROW FACING TOWARDS THE CENTER CONSOLE!!! Let us know man
                        got fix already mang put da new chip on da rite way and it runs fine now. and thank yall for the HELP
                        AND PLEASE MOD DELETE THIS THREAD LOLS
                          no...i think we'll keep this thread going for anyone else that plugs the chip in backwards. Besides, i wanna sit here and yell at you some more lol
                            haha. glad everything is ok and working fine
                              so what really happend? your engine skipped time? im still confused.lol i get the whole chip in backwards thing...but what was the other problem you had initially?
                              Finally Up and Running. Numbers to Follow. Check my MR
                                maybe it caused him to backfire or jump timing, no one will really know... eh
                                haha i too noticed the chip was in backwards.. LOL
