turbo auto
    turbo auto
    so what are the goods an bads about turbo'n a auto f22b cb7 i wana hear it from u also what kinda tune i can do/use to tune it rite
    im gunna be using a t3/t4 turbo 3" tubing 440cc's full 3' down pipe an full 3' exhaust piping
    Turbo automatic would always be in boost since you dont have to come off the gas pedal....my buddy had an auto sr20det 240sx(s14) and bad ran a 13.5 with just 3in exhaust and greddy frontmount.
    Originally posted by steezyteg
    lmfao rota 5 star dude theyre called rota slipstreams
      hehe that might be to much fun haha
        tranny is gonna go after awhile trannies are very fragile.
        wat?
          i might just do da swap on an 5 speed car thati might get soon
            I researched this pretty heavily when i had my first accord...if your staying automatic you need to beef up your transmission.This meaning geting an aftermarket torque convertor,stall,and flexplate.With the money you will spend getting your automatic ready for boost,you could have swapped to a 5 speed twice.
            Straight answer,can you boost on an automatic? Yes.
            Will it last without supporting upgrades? No.
            spoonsportsaddict
              ya i really dont like da auto set up but hopefully ill be buying a 92 ex coupe thats 5 speed just gunna work on turboing that an keeping this auto annd maybe make it 5 speed but i will have 95% of da speed parts - the tranny an motor mounts but it should be to hare to get it u know? so maybe ill have 2 great cb7s by the spring if i play my cards rite!!
                i installed a turbo on my auto but realise how retarded i was.....so i took it off, sold it and did my 5 speed swap.....so much fun...i gave up turbo for 5speed
                view my ride: My Ride
                  blazen_accord has a turbo auto h22. He's making over 400whp, I think... I believe it's on the stock block and trans, too. At least he was a few years ago when I saw him... however, I'm sure something has given out since then.
                  Level10 can build an auto to handle boost. It just costs money. Tuning is difficult with auto, though. Most of the tuners on here stay away from auto. It can be done, but it's more straightforward with manual.
                    ya ive been looking around an thought why dont you guys all kick me in my balls an for get to auto turbo it haha jp guys but i was thinking of gettin a buddys 5 speed car an work around that in the spring time :P
                      Now is that actually true, because I've heard a few different responses to this.
                      Member's Ride Thread
                      Originally posted by mercyboy
                      I'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
                        Well, "always in boost" is a stretch... but with a 5 speed, if you value your transmission, you lift off the gas to shift. With auto, you don't. You hold the pedal down, and the transmission shifts. No closing of the throttle plate. No break in the exhaust flow that keeps the turbo spooled.
                          true that man an my auto already is beat to sh*t from da da racing an what not i do to it haha
                            Am doing a auto turbo I got most of the stuff I need to do this project coming very soon
                            2014 bisimoto parts coming soon
                              Hello Deevergote and fellow boosted auto cb7, I still have and daily driven my turbo auto h22. As said 400+whp does not last forever on stock engine block/trans. My LSD stock JDM H22 LSD Transmission sliped after 2 years of boosted fun. I'm now still running stock JDM engine and my 2nd LSD auto transmission but at a more comportable 338whp/289tq this put less strain on the engine and transmission. Big credit to my amazing tuner and greddy E-manage Ultimate.
                              To fellow auto cb7, the 440cc injectors will max out at ~245whp. WHich is good since your stock engine and transmission IF still in good shape and healthy should be able to last 4+ years (better if it is an low millage jdm auto LSD transission).
                              Few Words of advise if not mention already:
                              1. Turbo on Auto require more fine ECU tuning, in form of tuned ECU or very good pippgyback ecu.
                              2. install additional transmission cooler, oil cooler, check and change oil/trans fluid often. Auto trans have a lot more moving parts and create more heat so got to keep the oil/fluid clean and cooled.
                              3. None/Little stop and GO races- Auto are weak getting off the line and are prone to brake axle, damage transmission. Turbo Auto shine more on rolling race where the constant in boost (at WOT) is the advantage.
                              4. Power is useless without control! 400+whp is nice number on a cb7 and is good for 1/4 at a track but it suck badly on the REAL street. You will spin tires, break axle, wear out your tire so fast it become too costly ... it like driving a v8 on a go cart track - being limited on everything and everywhere.
                              5. And last learn from other sucess and mistake. Good reliable power is alway better then limited used braging high power number.
                              !!Turbo for auto when done right is best of both world, 4 cylinder (gas milage- when non in boost) and v6 power/torque when you need that extra power anytime:!!) Happy Boosting...
                              90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
                              < 317WHP/227WTQ@11psi> B/W S256 turbo, Daily Driving on 93 pump gas - since 2006. Driving Turbocharged CB7 Accord since 2002.
