Ebay Turbo Kit
    Ebay Turbo Kit
    I know Ebay Generic Parts brake but would this be a good starter setup? I think i would replace a few things but i just want to know if it would be worth it.
    http://cgi.ebay.com/ebaymotors/JDMS-...ht_5910wt_1010
    For the price of that eBay kit you could put together a nice DSM setup and actually have some quality control.
    Member's Ride Thread
    Originally posted by mercyboy
    I'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
      Ive read just a little bit about turbos but the DSM kit dont you have to drill another hole or something like that for it to bolt up?
        minus the actual turbo, waste gate and bov...and you have a good kit
        New paint job and bumper 8/8/11
        tsx retrofit
        f22b dohc boosted
        custom gauges pods
        Motivation is one of the keys to life....tell me "can't" and I wll show you I can
          You just have to make the holes a bit bigger on the manifold.
            im looking around, i want a good reliable turbo setup on low boost pushing maybe 210-220 hp. i dont think im asking for much hah.
              e bay does not make a turbo kit. they sell cheap Chinese kits for cheap. but believe it or not they are a nice starting point. the turbo cases are a little on the crapy side but if you stay under the recommended 10psi. they will last and work well. the only thing that goes wrong is the tube exhaust manni will crack with out warning so make sure you get the cast manni. also after GOOD use or about 2 years of mild use you will get a bit of shaft play, BUT believe it or not you can send your old crappy Chinese turbo to turbonetics and they will rebuild the turbo internals with quality part for roughly 250 plus shipping. (thats what i did and my old boosted cb7 had a cheap ebay kit and i ran a 197hp at 7lbs. with 272 cam and a mild build, and a 210hp with the rebuilt turbo at 9lbs.)
              but i also agree with what was said earlyer. for a bit cheaper you can part a first or second gen eclipse kit that will work a little better.
              good luck!
                Here's a useful PDF for a DSM setup.
                http://home.comcast.net/~ndd3d/TurboInstall.pdf
                It has a parts list in it as well as installation instructions specific for the DSM parts.
                If nothing else the parts list is a nice reference tool.
                  lol i was looking all over for that thread, ya beat me to it
                    good luck!
                    that sounds perfect for me haha id only be running 6-8 lbs. ill start maybe with the ebay shit then upgrade later. ill look into the DSM setup.
                      Thank you man! Great start thanks
                        yeah we know you are not asking for much..We all concerned as a cb community and we don't want anyone hurting themselves even if it is for a little boost...that is all it takes to cause lots of problems..Factory made or reputable company are always the best way to go, when it concerns mechanical engine components (pistons, etc.s). Just becareful with parts like these. Even though we all know that EBAY doesn't actually made the parts. It is the individual who make the parts without concern of human condition and sell it on EBAY giving them a bad name.
                        If you had caught me earlier, I had a Garret t3 for sale which you could have gotten the little boost you wanted...Be warned..Once you boost once you will want to raise it.
                        tsx retrofit
                        f22b dohc boosted
                        custom gauges pods
                          Haha i have a while to decide before i boost. Ill probably upgrade my suspension, tires, and brakes before though. But im pretty certain i want forced induction. I have plenty of time to research before hand.
                            most important over anything make sure you get a quality set up. no ebay. DONT cut your springs. go to weksos and get fuction and forms. free shipping good quality and cheaper.
                              Dude this has been discussed many times... it's all over the internet...
                              "ebay" turbo kits do work fine. but there is always some fine tuning that you have to do in order to get the cheap parts to work correctly. Also don't expect it to perform as well as quality parts after thousands of miles of abuse.
                              Don't expect to be able to just throw a chinese turbo kit on your car and be ready for a dyno tune. The turbo will have to be inspected and retorqued properly, a proper oil restrictor will need to be installed. The wastegate spring will more than likely not be the PSI that it is supposed to be. The BOV spring will more than likely be too stiff. And the manifold studs will more than likely be completely useless and will have to be replaced. And sometimes cheap hardware just snaps, like the cheap T-clamps, etc.
                              Is it worth it? Maybe it is, maybe it isn't.
                              If you are building a car that you want to run trouble-free for years, then it definitely not worth it wasting time and money on shitty parts.
                              If you understand the fine-tuning that needs to be done with these cheap parts.. AND if you aren't building your car with reliability in mind and you like to fix it all the time, then hell yeah, it is worth it!
