wrong?
I think there is some confusion from reading that. When referring to firing order I think he is saying the first to fire goes on bank one, the second to fire goes on bank two, the third to fire goes bank one, and the fourth to fire goes bank two again. This would be the order of 1342 on ours making the pairing of 14, 23 the right order. This even makes sense with his description of pressure. If 13, 24 was run each side would see a period of two pulses making high pressure follow by two periods of no pulses, this would make the pressure in the banks uneven all the time. Doing it the otherway the two banks would always be close to the same pressure and the changing affect is improved greatly by giving an empty pulse where the turbine is pulling creating a lower pressure in that bank while the pulse from the other bank is spinning the turbine.
