Which turbo is the 60 trim and which one is the 50? Trim has nothing to do with compressor/turbine wheel size, just the relation between the smaller "inducer" part of the compressor to the larger exducer. ( i believe... )
Either way the T04E is definitely an ebay turbo...
And i cant tell what the t04b is.
Either way the E wheel is superior and more efficient i believe and with the stage 3 turbine wheel should be a perfect match for your car even at lower boost levels.
If i was you i'd sell both turbos... and pick up a REAL garret T04E 50 trim with stage 3 turbine wheel.
