Aite yall dis shit is pissin me off. my car is just dies after i let it run for a minute and if i try to start it again it wont star, i have to wait for a while to start again den just dies again?
i just put on new distributor on it last nite and it still doing it and i pulled the CEL and i got 2 CELs, a 20 and a 9. on my haynes manual it say code 20 is electronic load detector, and that has somthing to do with my idling dropping to 500 somtimes and also just dies somtimes. and the code 9 is NO1 CYLINDER POSITION, it says to check the cylinder sensor and the circuit, and to check it is by checking on da distributor.
ionno what to do i just put on a new dizzy on it. a guy from autozone said my timing mite have jumped, but i checked my timing belt or cam gear if its loose, but its not.
aite yall i need yalls help on dis
i don't know maybe they gave u my old dizzy. jk i just know that i have went through 3 ignition moduels from autozone and they all had the same problem but as far as ur problem is i have no clue.
