external wastegate lines
    i was wondering where i ran my external wastegate..the top of the wastegate or the middle of it? there is 2 ports..i think it might be why im only able to hit 4lbs and bogs out real bad...and also why my bov wont open. thanks
      Regulator, aka boost controller?
      For me, I ran a t off of the brake boost boost line for vac supply for boost gauge and BOV. The WG gets vac from the compressor, and boost controller installs on the vac line going from the compressor to the WG.
      Does that help? ]
      The boost controller is just a controlled leak.
      So, you need vac to power the WG, and say the boost controller bleeds off 20% of your vac(lets assume thats what you have it dialed in for). Lets say normally it takes 8psi of pressure to open the WG under normal conditions.
      Now it will take 10psi of vac being generated to open an 8 psi actuator since 20% of your vac is being leaked. Does that make sense? Thats how a boost controller works, it tricks the WG into staying closed longer by bleeding off the vac supply. Therefore, the WG only sees what you are showing it in terms of pressure rather than whats being generated.
      Boost controller=Controlled vac leak.
      Can you elaborate some more? I can help resolve this, I just need to better understand what you are asking.
      Originally posted by wed3k
      im a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
        huh? dude didnt know how to hook up the wastegate. He doesnt need a boost controller, he could just vent the top port. or if he does it like the diagrams, he could just use a cheap aquarium valve to control the WG
          I originally saw your images, and his post and thought they were all his post.
            lol k
              yea i got it figured out. im used to internal wastegates..and wondered why there was 2 ports on the external one...i got it figured out. now to figure out the tune. thanks guys
