F22b2 dyno
    F22b2 dyno
    Stock f22b2
    Custom manifold
    eBay 50/63
    2.5" downpipe
    Dsm 450cc injectors
    @13psi
    Needs to go back on the rollers with new clutch and a bigger exhaust.
    Praise The Lowered...
    Nice!
    I like that you kept A/C and Battery in stock locations.
    I'm doing an F22b2 or B1 in a CD5 relatively quickly. I'm still skeptical on running stock internals, but I keep seeing people put out 250+whp. I'm only looking for 220-250whp, or whatever I can get out of a small 16g on 10-12psi. (not actually a small 16g, but an IHI vf39 (sti turbo)...exact same inducer/exducer compressor wheel).
    Good luck and keep us posted on the new tune. What clutch are you going with? I'm thinking of using the F1 Xtreme segmented kevlar. I had good luck with the stage 3 XTD, the F1 Xtreme (F1 racing) uses a stiffer PP still. I didn't mind the quick action of the sintered copper, but slightly less chatter would be nice.
    Mark
      Wikk is that whp or max hp?
        This is a customers car
        the clutch was replaced with a competition unit
        the car will be going under the knife soon
        changing the head for a better flowing unit (F22a)
        ported manifold
        better fuel setup
        should make 300-320whp when done
          Seems like a lot of work switching to the F22a for only 50whp. Feel like you'd get almost all of that with an F23 Intake manifold and bisi turbo cam. Seems like a shame to scrap the exhaust manifold and do all the necessary fab work...Re-re engine$, have head decked $, New Turbo manifold$, Maybe need to tweak exhaust parts $, Fiddle with different Power steering pump/brackets line $, etc.
          I have a cd5 as well and thought about doing the A6, but for 300whp on a boosted setup, I'm not sure it's 100% necessary.
          Good luck anyways!
            I agree... But were gonna do it anyways
            Most of the parts are on hand
            And turbo manifold will be modified to work
            300-320whp is starting figures
            A buddy of mine just made 440wheel stock f22a
