is f22a6 going to work with the po6 ecu and uberdata setup? or do i need an a1 mani cuz i really dont wanan fuck with changing it.
f22a6 question??
f22a6 question??
h23a3 cb7 turbo sold
FS: 1 Piece JDM Headlghts blackhoused
My Members Ride !
New ride
'07 GTI Mk5 6spd
Tags: None
i was just searching and reading older thread and i read sumtin about the po6 map not being compatible or somthing. i do know the a6 is better thus ofcourse do not want to get rid of it
. ok thanks everyone!
My Members Ride !
New ride
'07 GTI Mk5 6spd
run what straigh to th post-throttlebody. also whats IAB? so its fine if they are always open?Originally posted by fizzbob7which is bad for low end torque....if you run it straight to a post-throttle body vacuum, it will open just SLIGHTLY earlier than with the black box controlling it.......that's the best solution.......i didn't wanna bother wiring all mine up, so that's what i did....on my h22a, i did the same thing and it was fine.......leaving them open isn't though....really hurts 0-2000rpm torqueh23a3 cb7 turbo sold
My Members Ride !
New ride
'07 GTI Mk5 6spd
searc for IAB does not work thus its to short! and as of right now i dont know where the iab setup is cuz i never did anything with it.Last edited by fizzbob7; 05-08-2005, 03:17 PM.h23a3 cb7 turbo sold
My Members Ride !
New ride
'07 GTI Mk5 6spd
Yet another incorrect IAB post.
I was pretty sure you said that just leaving them open didn't hurt low end Fizzbob. At least that is what you said in our little discussion on IABs. Changing your story, eh?
Regardless.
If you want to hook the secondaries up directly to the IM you may do so. But please be advised. They will open any time you go WOT or are under positive manifold pressure (i.e. under boost) regardless of RPM. If you don't have the A6 ECU to set up with Uberdata, then I would suggest using the secondary hi power duct soleniod for your stock intake system. It is the one that was included with the little black box that bolted to the fender near your battery. It will allow them to open at 3500 RPM which is better than any time you go to WOT. It is actually not discernible from when the A6 ECU opens them at 4800.
Midnight. There are two vacuum lines that work the IABs. One runs from the manifold to the solenoid. That is usually what the extra little vacuum nipple below the brake booster connection is for. The second line runs straight from the solenoid to the diaphragm for the IABs. I will have to look at my setup to see which one is at the filter end of the solenoid and which is at the other end. If anyone else knows off hand, that would be great. Otherwise, give me a day or so, and I will look and then repost.
thanks to everyone who wasnt a douche
My Members Ride !
New ride
'07 GTI Mk5 6spd
There are 2 connections on the solenoid correct? And then there is another port on the IAB box right?Originally posted by owequititMidnight. There are two vacuum lines that work the IABs. One runs from the manifold to the solenoid. That is usually what the extra little vacuum nipple below the brake booster connection is for. The second line runs straight from the solenoid to the diaphragm for the IABs. I will have to look at my setup to see which one is at the filter end of the solenoid and which is at the other end. If anyone else knows off hand, that would be great. Otherwise, give me a day or so, and I will look and then repost.
the lines went>>>
-port under brakebooster port to the top port on the soleniod
- bottom port on the solenoid to the diaphragm
- IAB box to the back of the intake mani...and theres a filter in the vac lineKnowledge is power...in EVERY sense of the word
Hey Midnight,
I looked at the setup and there are 3 lines. The line from the manifold goes to the open port on the vacuum box. The 2nd line goes from the vacuum box to the solenoid port farthest from the little round solenoid filter. The 3rd line runs from the solenoid port closest to the filter, up to the IAB diaphragm.
I guess the purpose of that box must be to slow the release of vacuum pressure so the diaphragm opens gradually instead of suddenly.
Anyway, the solenoid always allows vacuum, so as soon as you close the throttle and go back to vacuum in the IM the secondaries will close, and then the solenoid will re-open when told to by the ECU in order to re-release the vacuum.
Sorry, not preaching to the choir, everybody knows that you know as much about engines as anyone on the sight, I am just rambling aloud to myself!
Hope that helps.
