whey guys what should my spark plug gap be for boost. i just bought NGk iridium one step colder sprak plugs but dont know what the gap should be. can anyone tell me b4 i put them in.
Spark Plug Gap
Spark Plug Gap
h23a3 cb7 turbo sold
FS: 1 Piece JDM Headlghts blackhoused
My Members Ride !
New ride
'07 GTI Mk5 6spd
Tags: None
ok new question arises, what is the stock gap. i was sure i could find it in teh search but no luck
My Members Ride !
New ride
'07 GTI Mk5 6spd
Stock gap won't work for the boosted. The spark gets blown out and when that happens the condition can be just as dangerous as detonation. With that said .028 is a great gap to still create power and not blow the spark out. Once u upgrade to an ignition box u can go back to stock gap and get the power back that your losing. U probably should have just got normal step colder NGK's and used the rest of the money to save up towards an ignition box or atleast a blaster coil if ur externally coiledKnowledge is power...in EVERY sense of the word
Nevrmind i found the asnwer in shopkey . For anyone else who is intersted in this it should be be .039-.043 in .
My Members Ride !
New ride
'07 GTI Mk5 6spd
If i may...i insist on running .028. I was blowing my spark out at 5psi once. Power would break up TERRIBLY at 4800rpm's which i later found was my peak torque. Closed the gap and i could actually make it all the way through the rpms. Please, i insist.Originally posted by prodigymbNevrmind i found the asnwer in shopkey . For anyone else who is intersted in this it should be be .039-.043 in .
thanks for all ur input. my turbo is still in my basement and not under the hood along with all the other turbo crap i have. so for now stock gap.h23a3 cb7 turbo sold
My Members Ride !
New ride
'07 GTI Mk5 6spd
I ran BKR7E plugs pregapped at .034 using an MSD ignition, with 14psi on a 14b turbo with no problems at all.12.5 at 114.6mph 15psi
11.7 and 11.5 20.5psi
F22a1
60-1 td06h turbo
Darton mid sleeves
85.5 wiseco 8.8:1 forged pistons
Crower pro billet rods
Custom ported head.
KMS valves
F23 headgasket
ARP H23 headstuds
H23 upper intake manifold
F22a6 lower intake manifold
Intake manifold is gutted
AEM EMS 1040u
FIC 850cc injectors
Walbro 255 pump
H23 manual trans
Prelude shifter assembly
Forbidden short throw
Nitrous Express Kit installed, never used on this motor
