Here's my plan...I wanna go with a light pressure (7-8psi) system and work around that to make power; i.e. through opening up the exhaust, custom cams, and extensive tuning. My goals are 200whp@6000rpm and an even 12.3+.3 A/F ratio across the board. I've been looking and seeing that turbos are not that expensive if I go used...here's my tentative parts list:
- T25/T28 turbo, $375 new
- 2g manifold, $100-$375 used/new
- Random side mount intercooler, $100ish used
- Pipes & oil lines, prob. another $200 or so
- BOV, $100-200 used
- 3" exhaust, $150 or so
- Gauges, $200 or so
- Oil cooler?
So basically I'd be putting up about $1500 + tuning time which I would either do on the road or just buy someone's map and plug in. Here are my questions though:
- What turbos fit on the DSM manifold flanges? From what I understand the T25/T28, 14B, 16G and 20G all fit, right?
- Are used turbos safe, or should I just go new?
- Can we use aftermarket and EVO VIII manifolds as well?
- What can I do about the front mount?
- Are there a lot of basemaps available?
- Is the actual install hard? I imagine the pre-tuning steps are something like putting a new header in, installing the tapped oil pan, and connecting all the pipes...maybe changing the front mount as well, right? The actual install is nothing crazy is it?
I'm just trying to get all these questions answered so I can start ordering parts...I'm gonna be free during August so I want to get it on and tune it then. I have 94K miles on it so I think it's ripe for the charging...anyways let me know any answers you have because I really want to do this.
- Oil cooler?
