toyota turbo
    toyota turbo
    can i use a turbo of a 1jz?? my boy offered me one of his turbos from his twin setup...but im not sure what out come could come with that u noe...so anybody noe if i can use that?
    let me get one for my teg, how much
    Back up and Give me 50 feet
      the 1jz is off the old 280z, right? If I remember correctly, they had a single turbo. Maybe your thinking 2jz...?
      Shift_BOOST
      BOOM!
        I hope 280z is not refering to Nissan. 1JZ and 2JZ are both Supra motors. He is talking about the CT26. It can work but you will need to make a custom manifold. Also it would not be a bad idea to get some 550cc injectors. I know the Supra uses 440ccs but all that air has 6 cylinders to go through vs. the 4 cylinders we have. I was actually going to do that but i decided to just go with the DSM parts since they fit easily.
          1jz and 2 jz are not just supra motors, lexus sc300 has the 2jz. And yes, I was referring to nissan, I got mixed up. The vg30 came in the 280z. sorry. I hate nissan and don't care for toyota, so I get there motors mixed up.
          Shift_BOOST
          BOOM!
            Research owns you my friend (even though you don't care for toyota or nissan, read this and you might).
            1JZ-GTE is a twin turbo 2.5 liter Supra motor found in the 90 and up models
            2JZ-GTE is a twin turbo 3.0 liter Supra motor found in the 4th gen.
            Do you know any Lexus's SC300's that came in America with a turbo? The motor you are reffering to has no T in it. The T in the engine code means there is a turbo. Both turbo motors have small CT25s or CT26's powering them depending on the year. Personally, I would prefer the big CT26 from the 3S-GTE in the MR2. It has been known to put out 400 whp with only a compressor upgrade, and will boost from just under 3K to redline.
            Other motors that come with the large CT26 are the 5M-, 6M, and 7M-GTE Supra single turbo motors. The date range is 86?-92. The compressor map is awesome for the F series motors and it would put out much more power than the DSM setup. Block rebuild is recommended though because that turbo flows alot of air.
              never said they were turbo 2jz, but a lot of people turbo them. and yeah, I don't know that much about those cars. You know a lot more.
              Shift_BOOST
              BOOM!
                I am here for the same reasons you are 92ex. To share and learn some informations to better all of us. I theorized this turbo kit before i went with the DSM kit only because the parts for this kit had to be completely fabricated and I was not willing to wait so long for all these parts. I may still do it in the future. My theorized kit goes as follows:
                Big CT26 turbo
                550 injectors
                2.5 charge piping
                Custom equal length Manifold
                3" DP
                Uber or Aem Standalone
                Block Rebuild
                The Big CT26 had been able to flow close to 600cfm on the Mr2 motors after the compressor and cartridge upgrade.
                  the vg wasnt in the 280z....
                  the vg30de was in the z31 300zx
                  Claire - '92 Mercedes-Benz 500E - AMG&Bilstein Treatment - The Wolf in Sheep's clothing.
                  Alice - '97 BMW 540i6 - Dinan Tuned. - Low Profile Weekend Warrior.
                  Felicia - '11 Ford Fusion - Luxury Package - Daily.. daily.. ugh.
                  Originally posted by JoshM
                  Okay to do: "I'm sorry I broke your mailbox, here's $100.
                  NOT okay to do: "I'm sorry I fucked your sister, here's $100.
                    Hmmnn, what was in the 280's engine...Its killing me because I know what it is. I will take a wild guess and say its the L28..maybe L28E.
                      HOLY CRAP! i started a war!!!
                      ok i was talking about the 1jz-gte that came in jdm soarers. my boy just swapped his sc400 and he got some parts left over, now i ran thru my niggas shop, and talked to the ***** that did the swap, he said, maybe i should use the 7m turbo becouse its so much bigger and flows better.... my bois twins are pretty small, and i dont think they will give me much of a difference... i guess.
                      among the things i'm getting are 4 1jzgte injectors i think they are 370's can i used these? kev( the guy that swapped the motor), told me to find out something if my honda injectors are low pass...or low frequency or something...
                      im also getting either one small twin, or 1 big ct26 that needs a rebuild.
                      im also getting a skyline intercooler, and misc. piping. i dont noe what dp to go with cus i have 2 3/4" piping from the flex. should i get a 3" dp or a 2 3/4" dp??
                      any comment?? btw i plan on doing a f22ax block rebuild and full port and polish h23 head. with a chipped ecu, for now.
                        Like I said before if you use the large CT26 build the block. If you are the small CT20, It may not give that much extra power due to its small stature. However it should spool up quickly and barely harm stock internals.
                          ^^^^^^ thats exactl what i thought, i was going to do a big ass turbo motor rebuilt and shit but looking at the cost of shit these days im going to need a lot more loose change. imk not using the ct20 anymore cus my it's kinda on the small side, instead my boy came trhu with a 20g, and some guy i noe wants to trade me for his 18g, but if anyone wants the 20g i'll trade for a smaller turbo...btw anyone noe anything aboput the german turbo series kkk? i herd they are good and i found a good one, but i dont noe much about it.. is this a good turbo, how does it compare to a t3 or 16g?? it comes out the mid 90's audi quatro...
