oil pressure restrictor
    i was wondering if a inline turbo oil filter would work just as well as the 14dollar restrictor. has anybody used one of these?
    http://linux.forcedperformance.net/m...ry_Code=SP-New
    i know its expensive on this site, but i have seen them for around 30bux.
    any insight on this instedd of using the stealthmode oil restrictor?
    what is the purpose of an oil restrictor and where does it go??
      the purpose is to reduce the oil pressure flow that goes through the turbo. on a car like ours, just hooking up oil lines to your turbo with your oil line kit is fine, but the oil pressure is higher than what the turbo was set from factory.
      So you want to reduce the pressure with a restrictor or valve that reduces the oil feed pressure to the turbo inlet.
      This can help with how the turbo spins, supposeably and could possibly effect lag significently.
      also prevents oil from being blown from the turbos's seals
      this is what i have read at least.
        bump for an answer
          what are you talking about he gave you an excellent answer
            no he asked a question... asking if it will work
              isnt this an actual filter element and not a restrictor?
              Formerly 91AccordExR33
              11.68 @ 127mph
              417whp/375wtq
              Sold: 8/2016
                Read what Backfire wrote, you may have missed his post.
                The restrictor is an adjustable valve...kinda like a faucet. I need one badly lol
                  yes it a filter, but if you read farther into it, it describes that when you place it on a dsm, you have to drill out the oil feed source to flow more b/c the filter element supposeably restricts it down to flow less.
                  it doesn't make to much sense to me, but from the way i read about it, it seems like it must use a small diameter hole to restrict pressure on the element itself.
                  anyways i fould a cut off valve from vaccum lines and i fabbed it up to my turbo, so i have a restrictor now.
                  but now i just have to find out how much i should turn the valve to restrict the proper amount. when i find a oil pressure gauge that will hook up to my line, i will find out the positive amout the valve should be closed to.
