Timing???
    Timing???
    For those of you who have a boosted f22 what do you have your timing set at? and how many degrees should i set my boost retard at to be safe?
    Quit Droolin and Start Spoolin!
    rule is 2 degree for every psi of boost, but if you manually retard the timimg, then your low end will run like crap since your about 10 degree retard. This is Ignition timing if your talking about camshalf timing then leave it stock, unless you have a regrind turbo cam and an Adjustable cam gear.
    get yourself an boost relate retard unit from MSD it call an BTU, it will retard related to boost and return to stock timing when you not in boost. I did not have an BTU and retard my timing only by 7 degree and blew my engine at 12psi.
    90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
    < 317WHP/227WTQ@11psi> B/W S256 turbo, Daily Driving on 93 pump gas - since 2006. Driving Turbocharged CB7 Accord since 2002.
      Actually from what I've seen you'll want to start out with retarding timing 1 degree per pound of boost.
        i totally agree, 1 degree per psi. and dont be stupid and run more than 10psi. i will gaurentee u, u will blow your piston ringlands.
        91 4DR Accord LX White Auto
        Generic Mugen Lip
        Generic Intake
        EX 4-2-1 Header
        Dynomax Muffler
        Skunk2 Coilovers 560lb/in and Koni Yellows
        ST Rear Sway Bar
        17" Eagle Alloys/Kumho 711's
          so whose right.. ?
          1degree per PSI
          or 2degree per PSI
          also
          what do u mean?? manually???
          Praise The Lowered...
            Originally posted by WiKKeDV16
            so whose right.. ?
            1degree per PSI
            or 2degree per PSI
            also
            sorry man but u're wrong. if u want proof go search honda-tech, where their are more boosted cars than their are here or any other accord site.
            Generic Mugen Lip
            Generic Intake
            EX 4-2-1 Header
            Dynomax Muffler
            ST Rear Sway Bar
              2 degree is to be safe, but most go with 1 degree per psi. so unless your boosting over 8psi, 1 degree retard per psi is just fine. Manually changing the timing is turning the distrubutor(sp?) on the engine. but once you set it manually then even if your not in boost the timing is retarded meaning, slower off the line and also slower when you floor the gas.
              AN electronic boost retard device will make retard only when it sense boost, so you don't lose power.. MSD BTU is one of them
