which turbo
    which turbo
    i was wondering wat type of turbo ud all recomend....
    i have a 93 ex cb9 and these are my plans
    (swap)h22a auto with lsd
    dhr im/tb combo
    dhr head package including
    dual valve springs, titanium retainers, dimond milling, fpr, machine big port, and valves (not shure on wat kind of valves (opinions wanted)
    dhr turbo cams
    pauter x-beam super rods
    resleaving
    dhr dishtop pistons not shure on size yet still researching (would love ur opinion)
    beefier head bolts
    completly upgrading the fuel system including high cc injectors
    trany oil cooler(or a standerd swap not shure yet)
    id like to run around 12-14 psi since the motor will be basicaly rebuilt
    and maby a 75 shot or so if every thing goes well and runs good
    Old Ride-New Ride
    u need a big boy lol. T3/T04e or if u got some cash for for GT35RS ballbearing, it will spool in no time and have power all the way to ur high ass h22 redline.
    h23a3 cb7 turbo sold
    FS: 1 Piece JDM Headlghts blackhoused
    My Members Ride !
    New ride
    '07 GTI Mk5 6spd
      yeah, i run a kinda small t3 60 trim.. i love it cause its fun to drive and spools super fast... but for big power get a bigger turbo sc61 maybe? and as far as juicing with turbo, its hard enough to fuel manage with just the turbo let alone running NOS ontop of it.. i wouldnt personally recomend it.. but im sure it can be done.. good luck man
        ok i was looking and i like to t3/t04e but wat trim would u recomend? and i was also looking at the gt's and i cant find a gt35rs the closest i see is the gt35r which like u said is dam expensive..but wat about the gt32 and the gt35 are they anygood?
        Old Ride-New Ride
          yes they are all very nice turbos. i am a big fan of garret gt ballbearing turbos as well as precision turbos such as the sc61.
          My Members Ride !
          New ride
          '07 GTI Mk5 6spd
            so ....t3/t04e or gt32?.........and wat trim
            Old Ride-New Ride
              I think that there's a thread somewhere on here about how to properly size a turbo for your application.
              However, if you don't want to do it that way then I would simply recommend a t3/t4 50trim .48a/r. The 48 a/r will help it spool faster, although you'll loose a bit of top-end, but you'll be making very decent power with the 50 or even 57 trim compressor. And you don't really need the ballbearing center section because the displacement is high enough to have good flow at lower rpm's, especially with a ported head/increased exhaust flow.
              Good luck,
              -Kyle
              SOHC Non-VTEC F-series for life
              "It is the fools prerogative to utter truths that no one else will speak."
              -Morpheus (The Sandman)
                i looked for such a thread but did not find it.......... and i hate to keep badgering u guys with wanted recomendations but should i run an internal or external wasgate and a small explination y would be awsome.......i made some research but it was unclear.
                Old Ride-New Ride
                  With such a large turbo I would run an external wastegate, simply because the flapper in an internal wastegate can only flow so much and then you run into problems with boost spike because the wastegate can't regulate the exhaust flow as well. Tial's 38mm wastegate is a very popular one, an should be sufficient for a street car.
                  -Kyle
