Its freakin awesome. It can run anything. Which means when I sell my car, I can remove it and save it for another setup...as opposed to the AEM which only works with Hondas...And I doubt I will get another Honda. I figure I can keep all the accessories and sell the unit + the software.
I am considering a Haltech E6. Here are the specs.
Thats some list...and thats only the entry level ECU. The E11v2 is nasty. That could prolly run a car by remote control...
Originally posted by Haltech Website
The HALTECH E6X is a powerful “real-time”
programmable fuel injection and ignition computer designed
to control most ignition type engines. Whether 1-6, 8, 10 or
12 cylinders, 1-2 rotors, naturally aspirated, turbocharged or
supercharged, the HALTECH E6X can control it.
E6X System Description E6X Specifications
For more information & free demo software please visit our website at www.haltech.com u For any enquiries you are most welcome to contact us at:
HALTECH: 10 Bay Road, Taren Point, NSW, 2229, Sydney, Australia | ph: +61 2 9525 2400, Fax: +61 2 9525 2991 | e-mail: sales@haltech.com
E6X Series Fuel & Ignition Control System
PWM outputs are as follows:
*electronic boost control *thermofan *anti-lag *VTEC
*engine control relay *NOS enable *BAC valve *shiftlight
*intercooler fan *turbo timer *stall saver *air con
*aux. fuel pump *staging signal *dual intake valve
*torque convertor
(not all functions are available at the same time)
The E6X is much more than a programmable fuel injection
computer - it provides logging of engine data and allows
access in real time to maximise performance and trouble-shoot
problems in a vehicle while running.
Trigger Signal Type:
Inductive Magnetic-(Internal
Signal Conditioning)
Hall Effect Sensor
Optical Sensor
Trigger Pattern:
Twin Trigger
Multi-Tooth
Subaru
Single Pulse per Cycle
Bosch Motronic (60t-2)
Nissan
Mazda
Diahatsu
Ignition Configuration:
Twin Distributor
Twin Rotor (Dist. or DF)
Single Distributor
Direct Fire: 1-4 Cylinder
Waste Spark: 4, 6, 8 cylinder
Injector Firing Mode:
Throttle Body (Batch)
Sequential (up to 4 banks)
Multi-Point Staged
ECU inputs:
MAPSensor
Coolant Temperature
Air Temperature
Throttle Position
Internal Barometric Sensor
Primary Trigger
Secondary Trigger
Oxygen Sensor
Spec Purpose Digital
2x Gen. Purpose Analog
Road speed
ECU Outputs:
Injector Drivers: 8
Fuel Pump Relay Control
Dedicated PWM Outputs (4)
Idle Air Control (IAC)
Ignition Output
Spec. Purpose Digital (2)
E6X Kit Contents:
Electronic Control Unit (ECU)
Main Wiring Loom (flying lead)
2 x Power Relays
Air Temperature Sensor (Extra)
Coolant Temperature Sensor (Extra)
Throttle Position Sensor (Extra)
Communications Cable
Programming Software
Instruction Manual
Injector Loom (supplied with full
harness kit only)
Accessories:
MAP Sensor (1, 2 or 3 bar)
Connector kit
Idle Air Control Motor / Housing
Electronic Boost Bleed Valve
Boost/Fuel/lgnition Trim Module
Ignition Module
Ignition Coils
Oxygen Sensor
System Features:
Number of Cylinders
Max Operating RPM
RPM Range increments
Max. Range
Number of Fuel Maps
Number of Ignition Maps
Number of Bars per Map
Fuel Correction Maps:
Coolant Temperature
Air Temperature
Battery Voltage
Cold Prime
Zero Throttle
Full Throttle
Injector Phasing (Seq. only)
Throttle Pump
Injector Trim (Seq. only)
Barometric Pressure
Ignition Correction
Maps:
Ignition Crank
Air Temperature
Coolant Temperature
1-6,8,10,12
and 2 Rotors
16000 rpm
500/1000 rpm
10500/16000 rpm
22/17
22/17
32
The E6X features:
Up to 4 fuel and 4 ignition channels (internal toggle)
4 dedicated PWM outputs
1 auxiliary input
1 auxiliary output (tacho output)
Dedicated closed loop idle control
Dedicated closed loop O2 correction
8 injector drivers as standard equipment
An internal barometric pressure sensor
New RA8 reluctor adaptor
Rev Limiter
Deceleration fuel cut
Datalogging to laptop
Flatshift
Dual Mapping
High boost software (up to 65 pounds with optional MAP sensor)
The E6X is capable of controlling up to 8 low impedance or
16 high impedance injectors. If necessary an additional driver
box can be added for more injector outputs. The E6X System
optimizes engine performance by giving full control over fuel,
ignition and auxiliary outputs.
Typical Applications:
Conversion from carburetion to fuel injection
Control of fuel injection on modified engines
Race and rally applications of all descriptions
Design and development purposes
Educational use by universities and colleges
Original equipment in cars and motorcycles.
The HALTECH E6X is easily programmed with an IBM
compatible laptop. Our patented system allows the user to
alter fuel and ignition timing at a particular load point by
changing the height of the column in a bar graph.
*torque convertor
Hall Effect Sensor
Optical Sensor
Trigger Pattern:
Twin Trigger
Multi-Tooth
Subaru
Nissan
Mazda
Diahatsu
Twin Distributor
Single Distributor
Multi-Point Staged
ECU inputs:
MAPSensor
Coolant Temperature
Air Temperature
Throttle Position
Primary Trigger
Secondary Trigger
Oxygen Sensor
Road speed
ECU Outputs:
Injector Drivers: 8
Ignition Output
E6X Kit Contents:
2 x Power Relays
Instruction Manual
harness kit only)
Accessories:
Connector kit
Ignition Module
Ignition Coils
Oxygen Sensor
System Features:
Number of Cylinders
Max Operating RPM
Max. Range
Number of Fuel Maps
Coolant Temperature
Air Temperature
Battery Voltage
Cold Prime
Zero Throttle
Full Throttle
Throttle Pump
Barometric Pressure
Ignition Correction
Maps:
Ignition Crank
Air Temperature
Coolant Temperature
1-6,8,10,12
and 2 Rotors
16000 rpm
500/1000 rpm
10500/16000 rpm
22/17
22/17
32
The E6X features:
1 auxiliary input
Rev Limiter
Flatshift
Dual Mapping
