is 28 psi to much for the f22 if u build the bottom end (rods sleeves pistons bockgard) and and fuel system and wat not?........this question originates becuase i origionaly wanted to boost the h22 but i found that to be a lil unrealistic (espesailly on the wallet)...but im still dead set on goin at least a lil past past 350 hp
too much?
If you already have both engines I would just build the h22 as building the bottom end should cost the same. 28 is very possible if you can find someone to tune the car properly.Originally posted by Mikeis 28 psi to much for the f22 if u build the bottom end (rods sleeves pistons bockgard) and and fuel system and wat not?........this question originates becuase i origionaly wanted to boost the h22 but i found that to be a lil unrealistic (espesailly on the wallet)...but im still dead set on goin at least a lil past past 350 hp
Oil leak?What oil leak? That's just sweat from all that horsepower!
Applied knowledge is power!
NITROUS FOR YOUR BODY
BIRTHDAYS ARE JUST AROUND THE CORNER
registration is free
cuz moneys has become a bigger issue and i still have to do a standerd swap..right now i only have 600 dollors and dont even have a job lol(im goin out tomaro for aplications) when u calculate in the lsd and everything i need for the high hp numbers thats a shit load of money and from my calculations the cheapest and quickest way to get to 350+ hp is to build the bottom end and run high boost.
Oh hell here it comes... Your right in shooting for a hp goal. as different turbos make different power at different psi. I've seen one h22 make about 270whp on 8psi and another built one make 340 at 8psi. Of course there lot more to it than that but still. Shoot for a hp goal and then talk to an engine builder.Originally posted by AcclipseH23H22s are overrated anyhow. Why shoot for a PSI Mike? Depending on your setup 400whp can be achieved on low boost.
Originally posted by koolkoreankedOh hell here it comes... Your right in shooting for a hp goal. as different turbos make different power at different psi. I've seen one h22 make about 270whp on 8psi and another built one make 340 at 8psi. Of course there lot more to it than that but still. Shoot for a hp goal and then talk to an engine builder.
Merry Christmas bud.
lol same to you.Originally posted by AcclipseH23
its never to much
h23a3 cb7 turbo sold
FS: 1 Piece JDM Headlghts blackhoused
My Members Ride !
New ride
'07 GTI Mk5 6spd
Reliable is only in the eye of the tuner...Originally posted by Mikehaha well im not mechanic i want it to be reliable too
. 350whp is not extreme, I already got that on a T04b 50 trim. Then again my engine is Dohc and flows a greater volume of air by design. Eh more boost then, I only used 10lbs.
yea i know wat ur sayin but i was just refing to wat prodigymb was saying....with the h22 i was gona shoot for around 480 and im shure the f22 can do that with some tlc but like i siad im not a michanic i want it to reliable becuase i wont be able to fine tune it when i can tell if something is goin wrong u know?...especialy since i want to drive it almost every day. i might eventully do a hybrid like you but that goes back to y im not goin with an f22b or a h22 in the first place (the cash)Originally posted by AcclipseH23Reliable is only in the eye of the tuner...
http://www.myspace.com/forced93lude
