Which wideband system is better, or that people prefer. The UEGO wideband o2 gauge, or the kind that requires a laptop?
Best wideband
umm well depends what u want to do .....
if u want to stare at an expensive looking gauge and see ur afs change very fsat or use ur wideband productively for tuning. if its the latetr then u need one that can log to a laptop! u will see ur afs at all rpms and be able to make changes to ur fueli and timing accordingly.h23a3 cb7 turbo sold
FS: 1 Piece JDM Headlghts blackhoused
My Members Ride !
New ride
'07 GTI Mk5 6spd
yup!
driving and trying to look at the gauge that changes like no other is pretty hard, and plus, it takes a lot longer to tune because if you only have the gauge, you dont really know at which rpm it was rich or lean. you have to guess everything.
Originally posted by slowhondaI was thinking of using the guage type because I'm going to run uberdata when I finish my turbo project, and if I'm not mistaken it has a datalog feature correct?h23a3 cb7 turbo sold
My Members Ride !
New ride
'07 GTI Mk5 6spd
The zeit program is much easier to read. The only thing that the ecu's datalogging is truely good for is seeing the exact water temperature and tracing in the map where you are...other than that its just ppl wanting to be cool.Knowledge is power...in EVERY sense of the word
Originally posted by midnite racer xThe zeit program is much easier to read. The only thing that the ecu's datalogging is truely good for is seeing the exact water temperature and tracing in the map where you are...other than that its just ppl wanting to be cool.
