Other quick question what can you guys think of that would make the car kind of buck and only want to run about 3psi? we are thinking ignition but we have changed the dizzy wires coil and plugs and still have the problem. what wierd is when you boost past 3psi starts jerking and you can see the tack jump around. I kinda think its wire related or the dizzy was a bad one. But if you guys have any ideas let me know.
I did some searching and i saw a post that talked about the knock sensor but i have an h23 and i dont think i have a knock sensor and if i did i think we can turn it off in uber so i dont think thats my problem.
Ive also herd fuel filter but it would be a problem that was always there and this is really only present when you get on it and try to push the car past 3psi.
We just changed both the regular o2 sensor and my wideband sensor $$$ and they are both reading good and not showing that the car is lean when i boost.
As for the ecu its mrx map (so you know its good)
weird thing is we srewed around with it the other night took the dizzy and all the wires off then put them back on and i took it out to see how it did and it ran great! no bucking or studdering and all the way to 6psi no problems so i came home and let my bf take it out and it started doing it to him almost immediatly. So i dunno what it is we are kinda of stumped on this one.
Any suggestions please let me know.
Thanks
Thanks
