Ecu Control?
    Ecu Control?
    Aites guys just need to know if any of u used ecu control before to tune your car.... i know MRX has but i couldnt get a hold of him on aim.....
    or if anybody know a site on how to use it? cuz ive been trying to use mine but i couldnt get it to work..... thanks
    explain what u've done so far. Got the correct com ports set up and all? I'll re-hook mine up tomorrow and let u know the settings
      forum.pgmfi.org
        yea i got the com ports right and i clicked on uberdata obd1, clicked on stock narrowband for o2 sensor.....
          port speed should be at 38400
          and after you press "connect" your pressing "start logging" right? Mine is on com port 4 by the way
          and if u haven't manually set the com port for it go to Control Panel>System>Hardware>Device Manager>Ports(COM &LPT)>USB Serial Port
          double click, change "bits per second" to 38400, then click advanced settings and set the com port to 4
          make sure all thats done first
