14b vs 16g oil lines
    As far as i understand, a 14b and 16g in essence are damn similar.... my question is if I get the stealthmode oil lines flanged for a 14b, would it work with a 16g?
    yup should works........ thats what i used on mine before
      The center section in an small 16g is virtually the same as in the 14b! It is a little larger, so if say you were to use a 16g guts for a 14b turbos center section, it would need some machining to fit the 16g wheel!! Another difference is the turbine wheel and center cap is mated for the 16g wheel! Also the 16g plate has a taper! What the H, here you go! http://www.vfaq.com/mods/Turbo-rebuild.html
      WaC!
