what gains can be attained from porting out the a/r housing and o2 housing on a 14b turbo?
how much does porting help?
What are the benfits/gains of porting the turbo system? Depending on what supporting mods you have and how much boost you run, this porting will give you anywhere between 10 to 35 hp. Naturally, the more restrictions you have already removed from other areas (exhaust system, intake, IC pipes, intercooler, etc...) the more power this porting will uncork. It will also allow you to run more boost because the turbo effectively acts like a bigger turbo. It will usually eliminate any boost creep problems you might have had (because of the wastegate porting) and in most cases it will still spool much faster (depending on how much you port). It also lowers your intake temps because the turbo doesnt have to work so hard to supply the same amount of air (and another benefit of this is better gas mileage... if you can keep your foot off the floor). There are also nearly zero downsides to porting, unlike alot of other mods where you have to give one thing up to gain another (and most of the time the thing you give up gets annoying after a while).
