Datalogging Doesnt Work
    Ok, well I bought the Hondalog from Moates.net, and I cant datalog on any good programs. Uberdata gets readings but they are SOO off like at redline it says 45RPM and the tps does not read.
    I found an alright program called ECU Control and that logs my RPM, IAT, SPEED, and does alright with TPS " it says 92% on full as my Safc says 100%"
    Anyone have and suggestions as to what I should do to make other programs such as uberdata to work?
    Thanks.
    The sig name is new from a local forum. sorry to confuse anyone.
    My Member's Ride Page
    The Accords gone but I will forever belong to CB7Tuner
    honestly i have never been that impressed with Uberdata. I would work with ECU Controle some more as its pretty good.
      yes, ubers datalogging is definitly sub par. ECUcontrol is your best bet
        ecu control is working for me, but im not getting any A/F ratio readings... all the other gauges are accurate... im thinking somethings wrong on the O2 sensors end, which would explain why the cars running like hell?
        1993 CB7
        2001 BB6
          try free log.
          or get crome pro.
            Im not getting and A/F reading either, but my cars running just fine. so hmmmmm.....
              ive read about people cutting j12 for it to work, pgmfi is your friend.
                im pretty sure ive reread pgmfi inside and out...j12 needs to be cut before you can even datalog in the first place i believe
                1993 CB7
                2001 BB6
