ok i know that this is going to sound like a stupid question but i was wondering if turbochargers cause high compression? i know that low compression pistons are supposed to be used in a turbo application...but i was looking at getting new valves and the two choices are high compression and standard compression...i know that the standard ones would probably work since i only want to run 8 pounds of boost and also the valves are skunk2...just something i was wondering...
high compression?
Umm well you can run high compression with a turbo setup but you better have a bad ass tuner...I have a vid of a teg runnin turbo and i think hes doing 11:1 or 10.5:1 compression but yea. Do you have the spec on both? I wouldnt think both had a difference maybe size wise?
Originally posted by accord93raceri was wanting to know if turbos caused an increase in compression? also would my car run on 9:1 compression if i didnt have the turbo yet?
no, they dont' change compression at all.......they do have an affect on back pressure if that's what you're thinking of
yes, your car would run fine on 9:1 compression.....you could run fine on 8:1 compression.....the lower the compression, the less hp and tq you'll have relatively speaking....and on the 7th day, deevergote rested and called his mom.
bmep is just a way to compare engines in a "common denominator" way......it's basically a result of compression, but you can raise the bmep without altering the cr at all.......you can do a lot of things to raise the bmep since it's related directly to power outputOriginally posted by SteveBThey can have the same effect, raising the BMEP.Last edited by rickyduckworth; 08-20-2006, 09:06 PM.....and on the 7th day, deevergote rested and called his mom.
lol.Originally posted by fizzbob7bmep is just a way to compare engines in a "common denominator" way......it's basically a result of compression, but you can raise the bmep without altering the cr at all.......you can do a lot of things to raise the bmep since it's related directly to power output
Gee...thanks for clarifying for them, Ricky.
It's not as a "result of compression", it's a result of effective charge density.
Keep reading, my friend.2003 Maxima SE Titanium Edition
1993 Suzuki GSX1100F 136bhp
