I know this info is available, i did search, but its not all in a nice single thread, which is what i want to create here i think this will be very informative, basically list your turbo engine build (as detailed as possible) in the format below, i will copy that info and edit this first post and post the setups here, for easy viewing, any comments/questions are welcome also. I want to make a nice easy to read setup thread, im building an f22b as we speak and want to see what others are using and how much sucsess they are having, im sure there are many others also interested
The format is pretty simple, basically on top list your engine and estimated whp (and 1/4 mile time if u want also), and then just list every mod that is relevent, engine build/turbo kit/tires/suspension.
FORMAT:
Engine and whp (h22 @ 300whp, f22 @ 150whp, jdm f22b @ 222whp, etc.)
Then list mods one per line (rods/pistons/valve train/sleeves/crankshaft/gasket/headstuds/oil pump/oil pan/etc.)
Turbo setup (turbo/piping/tunning software/manifold/intercooler/etc.)
Tires/rims/shocks/springs/anything else that helps you put the power down or make power
Comments about the setup or whatever else at the bottom
FORMAT:
