Anyone boosting and juicing?
    I know that people talk about doing both, but that its not commonly done. however, as some may know, i have a nos wet kit on my car already, and im looking into a turbo kit as we speak. im also looking into new pistons and rods, etc, etc, and come this winter, i am looking forward to combining the two. i know its a little risky but i think that if i take the necessary precautions, then things should be alright. id only really use the nos with it at the track and very seldomly. i miss the sound that a turbo makes, and our passat just doesnt do it for me.
    that being said, anyone else using both of these great equalizers?
    this post has been brought to you by giddy excitement.
    what shot are you gona be running?
    imo, if you're gona do anything smaller than a 75, you should run a dry kit. a wet kit will probably cause you to go rich as fuck.
    for one, you will be boosted and be running rich already, then when extra fuel is added from the kit, its gonna make you uber rich.
    id prolly run a dry kit richen the map a bit to be on the safe side.
    but this is all theoretical since i don't have any experience with nitrous on any applications.
      id most likely be sticking with a 75 shot, and maybe just having the 50 shot on for dd. not sure though. as far as i understand it the wet kit does add fuel, but i thought that it ran just the right amount so as to avoid rich conditions, and i thought that this would stay the same even for someone with turbo. however, my knowledge in this area is limited as well, so im not sure.
        make sure you get a good set of plugs and change the fuelpump and fpr
          when i saw ''juiced'', i thought you meant hydraulics later.
          Avoiding dirt at all costs
            ha, while i would guess that there is a turbo cb7 with hydraulics, my guess is still that there is no turbo cb7 with nitrous.
            i could be wrong however.
              I have a full NX wet kit on my turbo motor. Havent used it yet on this motor, but i plan to... On my old motor i had a 14b running 14psi with a 35shot and it was quick... I'm not going to juice my new motor until i see what it will do at 30psi all turbo...
              12.5 at 114.6mph 15psi
              11.7 and 11.5 20.5psi
              F22a1
              60-1 td06h turbo
              Darton mid sleeves
              85.5 wiseco 8.8:1 forged pistons
              Crower pro billet rods
              Custom ported head.
              KMS valves
              F23 headgasket
              ARP H23 headstuds
              H23 upper intake manifold
              F22a6 lower intake manifold
              Intake manifold is gutted
              AEM EMS 1040u
              FIC 850cc injectors
              Walbro 255 pump
              H23 manual trans
              Prelude shifter assembly
              Forbidden short throw
              Nitrous Express Kit installed, never used on this motor
                word, did that setup get you into the 12's? or was that on just 15 psi and no n2o? and 30 psi, man, just wow.
                  i never ran it on my old turbo setup.
                  with 12psi on my new motor i went 12.7 and with 15psi i went 12.5 but they were bad runs due to traction issues and misfire issues at the time...
                  F22a1
                  60-1 td06h turbo
                  Darton mid sleeves
                  Custom ported head.
                  KMS valves
                  F23 headgasket
                  ARP H23 headstuds
                  AEM EMS 1040u
                  FIC 850cc injectors
                  Walbro 255 pump
                  H23 manual trans
                    14psi w/ a 14b? wow
                    how long did you do that for?
                    Old Ride-New Ride
                      Originally posted by Mike
                      14psi w/ a 14b? wow
                      I had the 14b setup for about a year. I ran 12psi for about 10months and 14-15psi for 2 months... One day an oilseal in the turbo decided to let loose, which sprayed oil in the intake, while i was boosting, causing oil induced detonation which broke my ringlands...
                      F22a1
                      60-1 td06h turbo
                      Darton mid sleeves
                      Custom ported head.
                      KMS valves
                      F23 headgasket
                      ARP H23 headstuds
                      AEM EMS 1040u
                      FIC 850cc injectors
                      Walbro 255 pump
                      H23 manual trans
                        yea cuz i was gana say from what ive seen 14b's hate the much work
                        Old Ride-New Ride
                          I planned on getting the Ntercooler later on down the line. Its like lazy man's N2O, no need for a retune.
                            one of the guys here backfire32 he's got turbo and spray not running spray till he get's it tuned though. and ^ that kit doesn't run anywhere near the improvement you get from nitrous anyways.
                            My 91 Accord F22B DOHC MR
                            My 1996 Civic Ex H23A VTEC MR
                              True. I debated running direct port, but that will definitely finish off my F22B (I already use 15psi on it as my aggressive boost). When H24 is complete, I will go direct port.
