Wastegate question
    Wastegate question
    My wastegate shaft has no tension on it and im making no boost so i guess the spring took a shot.
    My question is the t25 and 16g wastegate actuator the same?
    1992 Honda Prelude S - Swapped F22A6 - Turbo 16g Powered!
    Mods: 3" Exhaust,450CC Injectors, DSM Manifold, DSM Ported 16g, Stealthmode Oil Line Kit, RFL BOV, JDM Black Housing Headlights, Clear Corners, Tinted Tails, Forbidden Short Shifter, Front Mount Intercooler, Chipped and Tuned P06 ECU - Tuned With Uberdata, Lowered 1.7,6 Puck Clutch"
    PARTING OUT F22A1
    i do believe i have one i can sell you... LMK
    To see my car click here
    Bordeaux Red Crew #8
      they are both set to 8psi but im not sure if theyre the sam part? Ive got a couple also!
      WaC!
        Yep just confirmed.. 14b and 16g are the same...t25..no.
        So who has a 14b or 16g actuator!!
        PARTING OUT F22A1
          16g wastegate is set higher then the 14b if im not mistaken. 10-12psi where as the 14b is 7.8psi
          Shift_BOOST
          BOOM!
            Well, not from my experience. both big 16g and small 16g are at 8-9psi.
            Although i have heard that evo3's are maybe 1-2psi more, but that's just a feeling.
            mark
              i swore iamanonymous told me his w/g was set higher, but i may be wrong as well because i don't have personal experience with the 16g.
              Shift_BOOST
              BOOM!
                yeah 16g are set at 10-12psi arent they
                Upgrade your mind before you upgrade your car
                "So. Cal OUTLAWZ "
                  Welp my ported 16g always did 8-9psi...never higher..i dont plan on running higher than that.
                  PARTING OUT F22A1
