Originally posted by chessboxer
Turbo'd!
Originally posted by chessboxerthanks, it was like putting together a puzzle.
and using a saws-all to get the stubborn pieces to fit.
I hear you on that one. That was one reason I decided not to turbo, that and I couldn't figure out how I was going to keep A/C (A/C is NOT an OPTION in AZ)!
Those all looked like painted aluminum though, right?
indeed, 2.5" the whole way. also, im going to wrap all of the charge pipes with the wrap, i just didnt have time today.
a quick question about the catch can.
if i dont have an intake and am just running mesh on there, how do i run it? i know to cap off the pcv valve spot, but is it ok to leave the breather as well, or do i cap it off too?
ive read the diy's, but they dont address a lack of an intake.2010 Taurus SHO - Livernois Goodies
Originally posted by chessboxerindeed, 2.5" the whole way. also, im going to wrap all of the charge pipes with the wrap, i just didnt have time today.
Remove the check ball in the pcv so it stays open full time, and you will see.the oil will not be denied.
well, i went in for the tune today and i found out that my clutch is bad, so no tuning was done. the car is going to set for the weekend until at least monday, and then we shall begin the tune and install of the clutch.2010 Taurus SHO - Livernois Goodies
heres the clutch http://www.racingxp.com/transmission...honda-aord.php
its an rps max clutch rated at 440 tq with a 48% increase in pressure2010 Taurus SHO - Livernois Goodies
Originally posted by starchlandwhat did you end up doing with the front motor mount and where did you route your charge piping on the driver side?
the charge pipes were routed through the areas next to the bumper with the help of widening the areas there with a saws-all. ill take a pic tomorrow once it stops raining and everything, as its definitely not going anywhere.2010 Taurus SHO - Livernois Goodies
