okay my well if u guys remember my turbo cd5 was throwing out alot of white smoke. Some of u guys said it could be the head gasket, or that i needed an oil restrictor. well today i decided to disconect the oil feed line and turn on the car on idle and it didnt throw out any smoke at all. can it still be the head gasket or what can it be???
opinions..
blown turbo seal...but you probably just destroyed your Turbo.
you might also want to plug the oil return so any ground up chips of metal don't get into your engine.
Check your oil level too.
Mine was SMOKING LIKE CRAZY when my turbo blew...pretty white smoke too.
disconnect a charge line too. as it may be leaking oil into the intake as well...thus sucking in oil.
Mine acted really funny when all this happen...so much so that i thought the engine was blown (when turning over, sounded like compression as gone)...it was weird.
check those couple things.
lol i didnt floor the car i just let it idle for like a minute, i dont think that might of destroyed the turbo. But i do think its a sealOriginally posted by mtnickelblown turbo seal...but you probably just destroyed your Turbo.
check those couple things.Upgrade your mind before you upgrade your car
"So. Cal OUTLAWZ
dood i thought u just rebuild the turbo? how can the seals go bad unless the guy that rebuilded didnt put lubricant when putting the turbo together.Originally posted by dohcb7lol i didnt floor the car i just let it idle for like a minute, i dont think that might of destroyed the turbo. But i do think its a sealcontact info
(562) 324-3639 chan mao
yeah i know im just very frustrated with this thing that i dont even know what is wrong with it anymore...Originally posted by f20aaccordturbodood i thought u just rebuild the turbo? how can the seals go bad unless the guy that rebuilded didnt put lubricant when putting the turbo together.Upgrade your mind before you upgrade your car
"So. Cal OUTLAWZ
