Originally posted by aleks77
View Post
aleks77's Motor build + turbo setup build (extremely detailed)
i would keep the a6 runners and use the h23 plenum..i think you should get the bisi turbo grind..i think it will make more power than the delta 260 imo..OHIO CB7's
My Ride
MOD FUND: better if I could sell some of my stuff.
Build Thread
vouches: oneoffaccord, dep22build, 1993haccord, hostile, da9b16, brian91accord,93 Accord lx, kc8enb
ya i talked to bisi and he said it should do a way better job. Im gonna pick up an h23 plenum, and h23 throttle body also. Should i bother doing any porting? or sending the TB to maxbore.com and get it bored?1991 Accord LX Coupe - Boosted F22 - 5spd LSD - Shaved Bay - Work VSXX - Recaro SRD
Member's Ride Page | Video of my CB7, Open Downpipe peelout
im trying to make the same power..i found out these parts will help..so im learning from your setup..OHIO CB7's
My Ride
Build Thread
if you ever decide to replace your turbo manifold.
I'll recomend you get the DNP (DN Performance Tubular Exhaust Header) for the 2nd gen eclipse, And then port match it by hand to your gasket setup after you redrill the holes to fit.
you'll get almost 2 times quicker turbo spool up without snuffing out at high rpm's.
and it will never crack.. ever.
sorry i don't have a better pic, i had already heat wrapped it."Self Renewed"
Originally posted by aleks77 View Postya i talked to bisi and he said it should do a way better job. Im gonna pick up an h23 plenum, and h23 throttle body also. Should i bother doing any porting? or sending the TB to maxbore.com and get it bored?
http://polarbeartuning.com/Throttle_Bodies.html
You don't NEED to port match, but it would help. PBT also has a spacer that tapers down to the size of the plenum so that you don't have to bore the plenum out. Give them a call, they'll hook you up. Tell em you're on hmt too.
Originally posted by d112crzy View PostI'd spend the money on getting a BIGGER throttle body.
You don't NEED to port match, but it would help. PBT also has a spacer that tapers down to the size of the plenum so that you don't have to bore the plenum out. Give them a call, they'll hook you up. Tell em you're on hmt too.OHIO CB7's
My Ride
Build Thread
ya the "BALLER PBTUNING SPEC 74MM THROTTLE BODY" looks pretty good. Im gonna email him and see what he can do for an h23. Thanks for the site1991 Accord LX Coupe - Boosted F22 - 5spd LSD - Shaved Bay - Work VSXX - Recaro SRD
