okay ladies and gents. i am one week away from boosting a USDM H22a4. other than a 5 angle valve job, its a stock engine. im sticking to one head gasket so the compression ratio is still 10 to 1. i would like to know, through fellow tuner's experience, the safe number of psi and horsepower to strive to put out on pump gas. the fuel system is upgraded to a walbro 255 with 550cc injectors, and the turbo is a T4OE.
boosted H series on 91 octane
You want to avoid detonation at all costs due to the h22 pistons weak ring landings and tend to be the first thing to go under boost. Just have it tuned by a reputable tuner and I wouldn't go past 10psi on 91 octane gas and that compression ratio.Carlos
My Members Ride Page
i was aware of everything you said EXCEPT the 10psi part. you are actually the first person to suggest 10 pounds. i hear 7 or 8 psi is PUSHING it. of course i know the proper tuning is ESSENTIAL, but do you have any idea as to at what psi the ring lands give out?Originally posted by Accord SiRYou want to avoid detonation at all costs due to the h22 pistons weak ring landings and tend to be the first thing to go under boost. Just have it tuned by a reputable tuner and I wouldn't go past 10psi on 91 octane gas and that compression ratio.
10 PSI is doable BUT if you romp on it constantly your asking for something to give out. 7-8psi is kinda safety cushion. But a reputable tuner is always nice for tuning as accord SIR said.
Offcourse 10psi is max, if daily 7psi would be enough. The f22 and h22 flywheel is the same.Carlos
sweet. these rice burners out here are in for a surprise. they havent seen a BOOSTED DUAL CAM ACCORD out here. but back east, you guys do it like its second nature. question, i was checking into maybe lowering the compression a little. does anyone have any idea how much two stock head gaskets will lower the compression ratio to? it shouldnt be much, but i am curious...
You are looking to get a blown head gasket that way. Get a thicker Cometic head gasket. And to lower compression you might want to look into low compression pistons for the h22. Mhale gold series pistons will work with the h22 stock sleeves.Originally posted by 4doorkillersweet. these rice burners out here are in for a surprise. they havent seen a BOOSTED DUAL CAM ACCORD out here. but back east, you guys do it like its second nature. question, i was checking into maybe lowering the compression a little. does anyone have any idea how much two stock head gaskets will lower the compression ratio to? it shouldnt be much, but i am curious...
detonation is usually a small, sharp, thin edge (they heat up faster) in the combustion chamber that acts as an igniter.
the valve job won't really aid in controlling detonation and if you bump your timing down too low, you may melt your manifold.
the BEST "trick" to keep detonation at bay is to simply get rid of as many sharp edges in the combustion chamber. smoothing off the edges of the cylinders and around the valves in the cc of the head will make a huge difference. i had detonation problems with my xr4ti and the timing and boost were something i wasn't going to sacrifice, but after i took a dremel and rounded everything off a bit, it disappeared.
another trick is to add a gallon of race fuel to your tank of gas. i had a gas station that sold it locally and it wasn't a big deal, but can be annoying. octane booster is shit though.
but while it's apart, just smooth off all the sharp, thin, easily heated angles and it will make a difference and isn't much work....and on the 7th day, deevergote rested and called his mom.
actually, the thicker a head gasket is, the easier it is to blow out.Originally posted by bruno8747You are looking to get a blown head gasket that way. Get a thicker Cometic head gasket. And to lower compression you might want to look into low compression pistons for the h22. Mhale gold series pistons will work with the h22 stock sleeves.
less than 10:1 compression will be very counterproductive at that boost level too.
most people aim for 9-9.5:1 with boosted 4 cylinders, but they're running 20psi too. that compression is what's going to get you off the line fast until the turbo is wide open....and on the 7th day, deevergote rested and called his mom.
