One guy from the crew down in huston, tx called Visionboy. the is300 the one guy owns has a higher boost switch. When he takes off its set to like 12-14psi, then when he pops it into 2nd gear, he flicks the switch and that raises boost presure to like 21-24psi. can i make that work for our cars? like take off at 8psi and flick a switch to 12psi?
Higher Boost Trigger Switch
you would need to by an electric boost controller. Greddy has one but they are pretty pricey.~Nick~
I saw a electric boost controller with a steering wheel mounted controll w/ hi and lo setting. I'll see if I can find it for you.
edit: I found one but I don't think it has the steering wheel mounted control.
http://www.modyourcar.com.au/product...oducts_id=2390
its the same one his roommate is selling^^^^^Last edited by rudy1980; 08-30-2007, 02:29 AM.MR Thread- I brought SEXY back- LOL
If it jams, force it. If it breaks, it needed replacement anyway.
Never argue with an idiot, they drag you down to their level and then beat you with with experience!!!
