ok guys, i just traded my 91 civic si b16 hatch for a 92 integra b18 turbo. the teg needs a turbo tune job. does anyone know where i can get this car tuned???
turbo tuning
Any performance shop with a dyno.
Every shop has its rate...Most expensive around dallas for one of the best around here is about 170 per hour depending on system. Some places will do cheaper.
street tuning is like your driving around on the street with a laptop thats monitoring all your stuff....then you adjust according where you feel you need to...Its not as precise as as dyno tuning but it gets the job done until you can get to a dyno shopOriginally posted by CB7Junkiewhats the difference between the two???
I can tell by your question that you should probably take it to a dyno shop and let those guys do what they need to do
edit: no offense intended at all
Street tuning= get it running safe. Most of street tuning is concentrated on getting the correct air/fuel ratios so that you don't run too lean or rich. If the tuner is more experienced, they will mess with timing if they have their tools. There's no way to tell if what you're doing is making any power changes tho.
Dyno=trying to get the most power out of the setup.
It's always best to street tune before you dyno tune. It saves you dyno time(which=money), and it's faster too.
Originally posted by CB7Junkieok guys, i just traded my 91 civic si b16 hatch for a 92 integra b18 turbo. the teg needs a turbo tune job. does anyone know where i can get this car tuned???
In the link below I have includedthe Honda-Tech tuner directory.
Honda-Tech Tuner Directory By State
Good Luck!Last edited by kamaccord; 09-06-2007, 08:41 PM.
Wow that is really expensive, but thats using Hondata. What are your mods anyway?
