newtuner7 turbo h22 build
    ok so i am starting a build on a spare h22 i have...
    this is going to be kinda me asking if what i want to do is going to result in good power gains and whatnot.... if you see something wrong or want to suggest something feel free to do so and explain why please
    the head will get a mild to medium port and polish and get supertech dual valve springs and ti retainers. believe i will get sh cams and i have inline pro adjustable cam gears.
    oem head gasket and arp head studs
    new bottom end but nothing fancy for this rebuild... will be getting eagle esp rods and cp pistons once i get a new block to re-sleeve.
    as far as turbo i havent decided yet but am looking for something that spools quickly and will be efficient.
    i am also doing the h23 manual tensioner and getting a kaizen balance shaft elminator
    other mods are esp mounts, 3" exhaust, traction bar system, rear disc conversion, h22 tranny, bisi lightweight flywheel and clutch, bisi intake spacer, and w/e else i need.
    i am sure i am forgetting something
    edit: i decided to go ahead and sleeve the block i have so that will get done hopefully within the next 2 weeks. also going to go ahead and get new rods and pistons... head work to be done at a later date.
