When the turbo went on and you had everything hooked up, what kind of startup issues did you guys have?
First Time Startup Question
I put fresh spark plugs in mine right before start-up, and didn't check the gaps, one was completely crushed together so no spark was made, and the engine ran on 3 cylinders, freaked me out bad.
I also forgot to hook up the wiring to one cooling fan and had an overheating problem when stopped.
Other than that all was good. L8rTurbo H23a3 build has begun01-01-2019
no problems with mine but make sure to prime it first remove something that will not allow your car to start such as ecu fuse. Hold it trying to crank for about 7 secs let off. Put fuse in try starting it up. But i just had some smoke from burn off. Everything else was fine. A little bit of a high idle but it was cold out so ya. But just make sure everything is connected b4 you do and check them one more time and you should be straight
~Nick~
u don't have to do all that to prime the system all u have to do is move the key to the on position (not the acc. or the cranking position) u can hear the fuel pump start to pressurize the system do this about 2-3 times and u should be goodOriginally posted by Grumpys93no problems with mine but make sure to prime it first remove something that will not allow your car to start such as ecu fuse. Hold it trying to crank for about 7 secs let off. Put fuse in try starting it up. But i just had some smoke from burn off. Everything else was fine. A little bit of a high idle but it was cold out so ya. But just make sure everything is connected b4 you do and check them one more time and you should be straight
it's not the fuel system you're priming, but the oil system.Originally posted by quaidumu don't have to do all that to prime the system all u have to do is move the key to the on position (not the acc. or the cranking position) u can hear the fuel pump start to pressurize the system do this about 2-3 times and u should be good
Building the oil pressure up is why you prime it.Last edited by d112crzy; 01-25-2008, 11:26 PM.
On a new engine, there would be no oil running through the engine at all.
if you have a turbo, it's smart to fill the turbo and spin it by hand before installing it.
on a normal engine, it doesn't really matter. Before I knew about cars, I would just start the car and go on with my life after and oil change.
Now I prime it. But it's more important to do so with bigger engines because it takes longer for the oil to build up pressure. without pressure, you'd be running your engine nearly dry.
Yep, on new motor I found easiest way was to fill motor with oil. Then, pull "ECU" labeled fuse from underhood fuse box. Crank over motor (no spark or fuel because of pulled fuse) until your stock oil psi light goes off or if you have oil psi gauge it starts building up pressure. Then, reinsert fuse and start it up.Originally posted by d112crzyOn a new engine, there would be no oil running through the engine at all.
A new motor should have engine assembly lube on all moving parts for initial crank anyhow, you should not assemble it dry.
so guys, right now my rebuilt motor has barely any oil in it. and the turbo is clean inside. so i should add some oil into it and spin the compressor wheel so that the oil circulates through? then i should pull the ecu fuse and crank the motor until the oil builds pressure?miss my turbo cb7
sold
sold
sold
sold
